Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Thinking about potentially buying
Old Aug 27, 2011 | 11:06 AM
Nooch's Avatar
Default Thinking about potentially buying
a '04~ civic
What are some common things to look for when buying one?
Common problems?
EDIT: Is this the forum for hybrid civic's of the same year too?
Old Aug 27, 2011 | 12:17 PM
EM2abe's Avatar
Default Re: Thinking about potentially buying
Just like any other car that you'd buy... I normally look at the brakes, oil, hoses, belts, tire wear, underneath the oil cap(look to see if any oil is caked in the underside of it), color of power steering/brake fluids, blah blah blah.... drive it around a bit, you know? same old stuff.
Old Aug 27, 2011 | 01:55 PM
toyomatt84's Avatar
Sanji
Headgaskets can be an issue, and so can the air conditioning system. I'd recommend looking in to the coolant system before purchasing.
Old Aug 27, 2011 | 07:43 PM
lordhelmet1584's Avatar
While its an easy fix with energy suspension poly bushings, I'd check the front compliance bushings. If its an lx, check for exhaust manifold cracks.
Old Aug 28, 2011 | 09:59 AM
Nooch's Avatar
I know but I meant more stuff like below. Thanks though.
Old Aug 28, 2011 | 10:06 AM
PandaEj6's Avatar
Dont even consider it if its an auto. Those trans are well known for taking a big fat **** after 100k miles.
Old Aug 28, 2011 | 12:46 PM
Originally Posted by Nooch
a '04~ civic
Common problems?
I believe it is. Do me a favor and take some pictures of the under body aero panels.
Old Aug 28, 2011 | 08:37 PM
Nooch's Avatar
Haven't chosen a specific car, just asking.
I also wondering how hard is it to work on a hybrid. I can take classes (like I'm currently doing for other auto ****) for alternative fuel/systems. But I like DIY **** and pretty unsure about how safe/fun they can be to work on.
Old Aug 28, 2011 | 09:09 PM
EM2abe's Avatar
if you check the head gasket, then check the head for any warping. get a leak down test done. and also do a carbon monoxide test. also check the shocks/struts to see if they are blown.
boostit2120
Jul 25, 2013 11:01 PM
hbcrazy88
Jan 22, 2011 11:27 AM
imachikciviclover
Nov 11, 2007 03:11 PM
SlammedGsR
Nov 17, 2003 01:15 PM
