CA 1996 Honda Civic Hatch Turbo (CA)
Unfinish project 90% complete clean and clean title pink slip up to date I don't have the space nor the money to finish it asking 6k 9093338181. Ontario CA
Everything is new or redone. All is installed
-head obd1 gsr hot tank ,new seals,polish gsr cams ,3 angle valve job ,all zero miles.
-block jdm b16 .750 ls over size pistons 9to5 compression,bdl block guard,polish crank ,type r water pump/ oil pan tap ,type r pully,innovative race poly motor mounts. All zero miles
-jdm b16 tranny new seals ,bearing and hot tanked/ type r shift links with
poly bushing.
-turbo 63AR 60trim with god speed intercooler kit, god speed ram horn headers, tial wg, hks bov,hp racing intake manifold ,600cc lucas injectors,255 welbro fuel pump,3bar map.
-ecu obd1 p30 hondata s100 chip for this set up (bisimoto)
-paint oem stain silver 2stage base and clear less then a year old cut and already buff ,ion clear headlights, oem wing,sir front lip ,vis carbon mirrors ,aftermarket sunroof tilts and slides.
-15" +33 racing hart cyber wet black (redone) 195 flaken ziex black moteg lugs.
-supension 8k coilovers Tokico blues, hight end race traction bars ,spoon f&r strut bars.
All is needed from the top of my head is vtec solenoid+gasket ,valve adjustment , timming and a good tune.
LINK FOR SOME PICTURES OR TEXT ME
http://inlandempire.craigslist.org/cto/2557382899.html
poly bushing.
poly bushing.
poly bushing.
Chris.B.
Mar 5, 2008 09:29 PM
