Brake Light Pedal Stopper
a screw/nut to replace the rubber (tab?) that presses the brake pedal light sensor down?
The rubber fell apart the other night and now the brake lights are stuck on.
If so what size?
If so what size?
You can loosen and adjust the brake-light switch till the brake lights turn off (hopefully). Then in the mean time, order yourself a new rubber grommet for the pedal. I had to replace one once cause it fell apart on my REX. I think it was for the clutch switch though...
i stuck a bold with a small head and screwed it down with the propper nut, and adjusted the switch to the extra mm of the bolt head.
Has been workign perfectly for about 3 months now.
Common problem, there's a huge thread on it already
https://honda-tech.com/forums/showth...ht=brake+light
This just happened to me last night! I was wondering when it was going to go. I used the ghetto method of taping 2 pennies to hold me over until the part comes in from Honda.
Cheapest fix is to use a normal-big zip-tie. Attach the zip-tie where the old rubber tab use to be & make sure the fat end of the zip tie sits right there. Bam problem solved! I fixed mine in this manner & have never had problems ever since.
BlueIntegraBoy
May 26, 2021 10:40 AM
gsrsuperman
13
Jul 21, 2008 10:20 AM
