Car dying
Old Aug 26, 2011 | 12:02 AM
yaaagin's Avatar
Icon3 Car dying
just bought a ef hatch 5spd. and im a noob driver so i always die out but the after a few times dying out, the thing takes long to start (like 5-10 min). but tonight we had to push start the car.... theres always that click sound everytime it fails to start. im wondering ... is it the battery or altanator. idk tho. whats your input?
and its sorry im new to this tooo and its my FIRST CAR
Old Aug 26, 2011 | 03:33 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: HEEEEEEELP!
Alternator... Is your battery light on?
Battery... When it turns over, is it slow or fast? Are your really dim?
Starter... If your batter is proper most likely you burned up your starter...
Old Aug 26, 2011 | 05:25 AM
yaaagin's Avatar
yeah my battery light is on... so what does that mean the alternator is screwed? or just change battery. sorry like i said im new to this car stuff.
Old Aug 26, 2011 | 05:44 AM
Aftermath_Hatch's Avatar
new alt. maybe new batt. to
Old Aug 26, 2011 | 07:14 AM
DO IT ON ALL FOURS
Battery light is strictly for your alternator and indicates a no charge situation. Most likely your alternator is bad... if you don't want to spend the money you can take it out and have it tested at your local parts store. These test sometimes give a false reading but for the most part are accurate (mainly because the alternator is cold when tested). Do yourself a favor and put a new belt on there while you are at it.
Old Aug 26, 2011 | 07:40 AM
ej1b18c1's Avatar
replace alternator--recharge battery if you can save it, if not replace battery
Old Aug 26, 2011 | 01:46 PM
yaaagin's Avatar
aight thanks everybody! ill try to get this **** start as soon as i can. ill post pics of my ef probably later. shoooots!
Old Aug 26, 2011 | 02:12 PM
yaaagin's Avatar
btw where is a good place to find an alternator and the belt? junkyard, ebay...?
Old Aug 26, 2011 | 02:15 PM
osoriodavidjdm's Avatar
get it new, or if u get altenator used make sure they have warranty, u might buy one with same problem as urss
Old Aug 26, 2011 | 02:42 PM
KINGVEM^^ED6's Avatar
go to vatozone they will set u up
Old Aug 26, 2011 | 06:01 PM
94eg!'s Avatar
#1 Super Guy
Loved
If the alternator is bad, the car will die when your driving. Your radio will go out first. Then the car will eventually die as voltage drops lower and lower.
If the battery is bad, the car won't start (start makes weird noises). It WILL start and run fine if you give it a push and dump the clutch or jump-start it.
Old Aug 27, 2011 | 12:19 AM
yaaagin's Avatar
yeah it doesnt die out while driving, and the radio never dies out.... sooo i guess its battery right? but yeah ill buy new battery then ill let ya guys know. thanks for helping man!
Old Aug 27, 2011 | 12:23 AM
yaaagin's Avatar
battery
alternator belt
View My Video
starting up the car.
yeah im clean the terminals, then if it doesnt work change battery
Old Aug 27, 2011 | 07:51 AM
94eg!'s Avatar
#1 Super Guy
Loved
If you want to see something cool, pour a small pile of baking soda (not baking powder) onto that corroded terminal. Then pour a cup of water onto it. It'll fizz up good and the terminal will look brand new after one or two applications. That build-up is powdered acid, and the baking soda is a base. They react with one another and turn into salt water. The terminals should look nice & copper again.
I just cleaned off the tops of two batteries last night with this technique. Amazes me every time. I had a bit of buildup on the bars that hold the battery down. Now they look nice again.
Also, check to make sure all your grounds are tight. This buildup can be caused by loose engine or transmission grounds (or so I was told).
Old Aug 27, 2011 | 11:30 AM
DO IT ON ALL FOURS
In a pinch you can also use Coca-Cola... (has to be name brand to work good).
Old Aug 27, 2011 | 12:43 PM
94eg!'s Avatar
#1 Super Guy
Loved
Coke is acid. Putting coke on it will just disolve the powdered acid into a powerful liquid acid. That sounds not so good.
Putting a base like baking soda on will neutralize the acid. Yay!
Old Aug 27, 2011 | 04:13 PM
DO IT ON ALL FOURS
I know all this... I said IN A PINCH... Coke will at least dissolve it then you can wash it all down... Unless you are doing heroin or something why would you be soo scared of the acid? If your terminals are so bad that it won't make a good connection and you are on the highway stranded, all you have is a bottle of Coke and a bottle of water (or pull a Bear and pee on it)... It will do the trick. You kids these days obsess the small stuff.
Old Aug 27, 2011 | 06:01 PM
94eg!'s Avatar
#1 Super Guy
Loved
Que?
1992redhonda
Feb 6, 2011 09:49 AM
busha61067
Feb 10, 2010 04:54 PM
vtec420kingH22
Apr 16, 2009 11:44 AM
BAYgasDC2
Oct 24, 2007 02:21 AM
biggdogg
18
Nov 26, 2003 06:32 AM
