Bad third gear syncro
Old Aug 25, 2011 | 07:58 PM
Taco_Meat's Avatar
Default Bad third gear syncro
I have an eg ferio, and third gear is really bad, pops out immediately, I'm forced to shift from 2nd to 4th. Should i replace the third gear syncro? Or, my bro brought it to my attention that I should save up for a gsr tranny, and do a full blown tranny swap... what would you do? oh it has an ls swap btw
Old Aug 25, 2011 | 08:24 PM
98civdx's Avatar
Master Detailer
Default Re: Bad third gear syncro
I assume your runing the LS trans?
If so, if you can afford the a GSR b16/ITR trans do it!
Old Aug 26, 2011 | 05:16 AM
ToTriggerHappy's Avatar
Rebuild it with ITR 1st and 2nd and GSR 3rd, 4th, and 5th with a ITR final drive.
Then you'll be golden!
Old Aug 26, 2011 | 07:23 AM
b18EK6's Avatar
If you decide to rebuild the transmission, use synchrotech carbon synchros, best decision I ever made. It probably wouldn't hurt to replace the synchro sleeves as well...
Old Aug 26, 2011 | 07:52 AM
ej1b18c1's Avatar
cheapest= get another LS transmission ugghh or if you want an upgrade get a gsr. b16 is kool but not for freeway. cheapest bang for you buck is to get a gsr w/ factory lsd, and if this is a daily driver it will be plenty enough w/ a good clutch/flywheel.
Old Aug 26, 2011 | 08:45 AM
Gearspeed-Performance's Avatar
I would stay away from a GSR with factory LSD. They break internally all the time at the neck inside the LSD. They also have a final drive setup that doesn't allow you to easily swap if you ever decide to do so(has a different bolt pattern). If you have a B16 now..going to a GSR will give you longer gear ratios and lead to decreased acceleration speed vs. the B16 trans. If you have an LS trans then either will be a viable upgrade. If you are having a pop out issue it can be the following: Synchro spring, worn sleeve, gear, fork or all of them. While you are there I would upgrade the synchros to carbon which aid in high RPM shifting. Let me know if you have any further questions and feel free to PM me anytime.
Here is a pic of a broken JDM GSR factory LSD
Old Aug 26, 2011 | 09:00 AM
Taco_Meat's Avatar
thnx guys, I'll probably save up fr the gsr, just feels weird not being able to shift to third
Old Aug 26, 2011 | 10:19 AM
What transmission do you have now?
Old Aug 26, 2011 | 10:54 AM
ej1b18c1's Avatar
I think he has the ls. Reason I was saying the gsr with factory lsd because if he's just DD it will be well enough, but if it's track car i would just rebuild what he's got with itr etc..
Old Aug 26, 2011 | 01:52 PM
That broken LSD is off a DD car actually(repaired it for a friend of mine)....Just age of the transmission and you never know its prior use before it got here to the U.S.
LS swap...duhh! I should read more carefully! lol
Old Aug 26, 2011 | 05:02 PM
98civdx's Avatar
Master Detailer
I did it too. I had it all typed out and looked up. lol
My buddy bought a GSR with a broken LSD. Guy finialy admited it later.
Old Aug 26, 2011 | 06:38 PM
ej1b18c1's Avatar
Ya it all depends where you buy the transmission from lol could look really clean on the outside but we all know that it matters from with-in. Now that you brought it up, a gsr trans used is more likely to be beat to crap than any other.
Old Aug 26, 2011 | 07:02 PM
98civdx's Avatar
Master Detailer
Exactly, looks are very deceving.(sp) lol This one looked new, but was shot when we opend it up.
Old Aug 27, 2011 | 04:31 PM
Taco_Meat's Avatar
Stock Ls tranny, my boy was telling me to try changing the tranny fluid. I'll do that when Irene passes and see whats up
Old Aug 29, 2011 | 09:20 AM
Fluid is not going to magically fix a damaged hard part inside a trans. So save your money on "magical" fluids. If a trans has an issue its got to be fixed no matter what. Some fluids may mask a grind problem..but its still damaged and will only get worse. Use that cash towards your GSR.
Old Aug 29, 2011 | 01:21 PM
easy_vtec's Avatar
X2! Save the trans fluid for your new tranny!
Mal_E_Mal
Dec 15, 2016 07:52 PM
Manny1987
Transmission & Drivetrain
Mar 27, 2011 06:25 PM
jchrm80
Sep 24, 2009 08:53 PM
Boostage
Nov 24, 2003 04:15 AM
Black R
May 20, 2003 03:02 AM
