94 accord ex water leak
Old Aug 25, 2011 | 06:12 PM
404notfound's Avatar
Icon2 94 accord ex water leak
I have water leaking onto the front driver side carpet after it's parked in the rain. I believe it is the front drain tube for the sunroof or at least I hope. Well I know I can blow it out if it's clogged but I fear it may be disconnected in the footwell area but not sure where it is located. I looked in my Pdf manual but it doesn't mention specifically where it's routed. Any help of where it's at would be much appreciated.
Old Aug 26, 2011 | 05:53 PM
poorman212's Avatar
Default Re: 94 accord ex water leak
I've seen this post somewhere before......
The tube is down the piller. If you are wanting the "outlet" side, it should be behind the inner fender of the tire.
Old Aug 26, 2011 | 06:43 PM
bdmlilburn's Avatar
th ac condensation drain tube is also located in the passenger area. may want to check that
Old Aug 26, 2011 | 06:48 PM
Ziprock's Avatar
check the rain gutter on your roof. Could be a rust hole. this happened on the pass side of my 94 ex. i couldnt find the leak anywhere. after giving up i peeled back the rubber that lays in the rain gutter and there was a dime sized rust hole hiding there collecting water, running down the a pillar and soaking the carpet around the ecu.
Old Aug 27, 2011 | 12:34 AM
L.a.'s Avatar
Im also having a similar issue with my ex when it rains the carpet behind the drivers seat gets wet
Old Aug 27, 2011 | 06:45 AM
Alright thanks guys I'll get on it today and see what I can find. And btw bdmlilburn my issue is on the driver side but I know what you mean I've had that problem in the past on another accord.
Old Sep 12, 2011 | 09:32 AM
L.a.'s Avatar
any updates 404?
jmccalip
Apr 12, 2013 11:29 AM
tr7driver
Dec 2, 2008 10:17 AM
Jun 10, 2004 08:56 PM
sidwin
Sep 7, 2001 03:43 PM
