high comp. b16a2 questions
probably a dumb question, but i have been wondering what all it would take to get my stock b16a2 with 10.2:1 comp. ratio up and around the 11's
i was thinking about doing CTR pistons, rods and crank. probably have the head shaved (but how much do i have to shave off) and port and polished. thinner headgasket. things like that
what else could i possibly do to have the comp. ration raised.
i wanna do a high comp. all motor setup.
thanks for all the serious and entertaining replies
Hmmm... from what I can dig up, the CTR pistons alone get you up in the 11 range.
The typical high-compression build for the Integra motors gets a GSR head for about 0.2 more compression, but I don't know if that works for the B16 block.
EDIT:
Found a good link - should help you a lot!
http://www.ff-squad.com/tech/temp/pistons.htm
EDIT:
EDIT:
EDIT:
thanks for that link.
best bet with the setup i have is the CTP pistons, and just have my connecting rods milled 1mm on each side.
ah thank you!
for the motor i kept it at b16a crank and block
b16a head
PCT ctr pistons
b16a connecting rods
and OEM 3 layer HG, and NO milled head or decked block
9000 rpm at 15 ft above sea level and it calculates about 11.9:1
godluvstegs
24
Oct 28, 2011 02:16 PM
slamdunkcivic
May 20, 2003 06:26 AM
