Front Wheel Bearings
http://www.youtube.com/watch?v=FEDrioMDe1k
Yes, he uses and air hammer but you don't need one. Just put the hub in your freezer for an hour or two and let the new bearing sit out in the sun awhile before putting the two together. Use the old inner race and a small sledge hammer to slide the bearing onto the hub.
I did this job last May so I have to think about it. Without a press you have be careful to get the bearing started straight on the hub. Once it's started then it's just a matter of using enough force to seat the bearing. So, yeah, I think you want the hub (the shaft) to contract so that goes in the freezer, and you want the bearing (the hole) to expand so that goes in the sun.
Looking at the video again, I noticed that Eric the Car Guy doesn't use air to get the new bearing on the hub. He just puts the bearing on top of a vice and pounds the bearing down using a big old bolt that fits over the race. Instead of a bolt I used the old (cracked) inner race. Same result.
im pretty sure he said it right.
when i am doing this repair i like to either have a shop press them in and out or order them preassembled. it can be very easy to damage the bearing by either forcing it on wrong or running the car with it off center
rexload
Jun 5, 2015 11:31 AM
Bnjmn
Sep 20, 2005 03:43 PM
