what injectors fuel pump and engine man
I have a lsvtec it's bored .20 over eagle crank eagle h beam rods srp 10:5:1 pistons b16a head port polish jg valves jg springs and retainers crower stage two cams msd ignition skunk 2 intake blox throttle body 68mm aem fuel rail What injectors fuel pump and engine management would u recommend I have a set of 440cc rc injectors will they work and I'm kinda on a budget with engine management right now
If they are RC 440. Ge rid of them and get OEM RDX 410 CC injectors that are like 40$ a piece and will be WWWAAYYYY better then RC's. I am able to lean out my car at light loads up to 19 AFRs due to them having really great atomization then after that it will break up. A guy on here said his rc's break up anything over 16.5. Never ran them butt i always tell my friends and whom ever is looking for a bigger injector that RDX are the ****. I have them. I love them.
For fuel pump a 255 walbro will be to much. I would get a 190 walbro. I am running my 410cc injector of a oem DC2 fuel pump that has almost 150 k miles on it. Runs perfect.
Keep the OE pump and put the extra money into the tuning.
Edit: unless you don't already have a pump -- in which case just get the cheapest Walbro you can find (190 or 255).
www.tunewithcrome.com Read, Learn, Best of Luck
b16nonoy
15
Jul 10, 2006 12:29 AM
