85 CRX hazard light issue
Old Aug 24, 2011 | 05:38 PM
jlgelinas's Avatar
Default 85 CRX hazard light issue
Hey all, bought a CRX recently because I wanted a fun car to drive and work on. Dealing with a problem now where my turn signals work, but hazard lights do not. I pulled a combination switch off a 84 CRX I found at a salvage yard and swapped it out, same problem persists (everything but hazard lights work). Any ideas on how to tackle this? I'm in the military and they do mandatory safety inspections, my car is going to fail if I don't find a way to fix this =P
Old Aug 24, 2011 | 07:07 PM
B18B1-Crx's Avatar
Default Re: 85 CRX hazard light issue
not too sure however i believe i had the same problem and my tailight where not working as well and it was a fuse thats in the engine bay that the same circuit ran the hazards?
Either Its something simple Like your bulbs or a fuse
the switches and harness last forever on ef
Old Aug 24, 2011 | 09:31 PM
ej1b18c1's Avatar
check relays as well as fuses or wires grounding out by the turn signals. Yes the harness can last forever if in good hands of it being taken care of but best way is to use a volt meter and test continuity to make sure there's nothing causing a short out or something. Do that after you have already checked fuses and relays etc..
Old Aug 25, 2011 | 11:27 AM
jlgelinas's Avatar
replaced the relay, no change. starting to think it's the wiring--- the turn signals work, but turn off when I turn on the hazard... I know the hazards are wired straight to the battery so it seems the wires associated with that are not working... oy. any tips on troubleshooting and fixing wiring issues without breaking more things would be awesome.
hatchyksp
Dec 8, 2008 04:54 PM
nipcup101
Lighting
Dec 31, 2007 05:51 PM
jchrm80
Oct 20, 2007 04:35 PM
CO_HaTcH
May 5, 2007 03:52 PM
