F/S Built GSR Motor made 587WHP FOR CHEAP!!!!!!!!
PRICE DROP $1500!!!!!!!!
I got a built gsr motor for sale. Only bad part is motor has 2 hairline cracks in cylinder# 4 BUT i will also include a bare gsr block with the sale so u can swap everything over. There was no other damage to any part of the motor except 1 sleeve. Motor made 587whp on 28lbs. Motor ran perfectly fine before it was removed from car it was just loosing compression in cylinder#4. In total i have about $5k in this motor. Everything was bought brand new.
Block b18c1
9.5:1 cp pistons
eagle rods
arp rod bolts
arp mainstuds
arp pressure plate bolts
arp flywheel bolts
arp headstuds
brand new oem headgasket
all oem bearings
golden eagle oil squirter plugs
oil catch can fittings
moroso oil pan
supertech block guard
fidzana 10lb flywheel
ACT pressure plate
new type r oil pump
new type r water pump
brand new alternator
Head:
Full port & polish
crower oversized stainless steel valves
crower dual valve springs
crower steel retainers
type r cams w/ skunk2 cam gears
new dizzy
arp exhaust manifold studs
copper exhaust manifold gasket
hondata intake manifold gasket
gates racing timing belt
valvecover w/ fittings for catch can
vtec solenoid
full engine harness
Like i said i have well over $5k invested in this motor & all u have to do is get the parts swapped over to the other block. I want $2500 for everything listed above & no i do not want any trades. Im located in CT 15min away from the bronx. 203-505-0830 call or text
Block b18c1
9.5:1 cp pistons
eagle rods
arp rod bolts
arp mainstuds
arp flywheel bolts
arp headstuds
all oem bearings
moroso oil pan
ACT pressure plate
new type r oil pump
Head:
Full port & polish
new dizzy
vtec solenoid
full engine harness
Nickb257
Sep 4, 2011 08:18 AM
Nickb257
Northeast (Sales)
Aug 23, 2011 04:18 AM
Nickb257
Aug 23, 2011 04:15 AM
JDMJNKY
Mar 20, 2007 10:56 PM
