axle or tranny problem?! em1
sup HT i changed both axle's on my em1. the driver side axle was tore up it would make a cracking noise when i would make a left turn sounds like if something was breaking. so i replaced it & still when i make a left it does that horrible sound. am i looking at a axle problem or tranny? please let me know thanks
get a passenger and roll the windows down, now both of you hang your head out and see which side its on. go from there.
thats the best way to tell
edit: do this in a parking lot and not on a street or something so you dont loose your heads
also, if you have a well trained ear you can tell if its coming from the outer or inner joint which helps to tell you whether its coming from tranny side or hub side
