Honda Civic 200 Battery Overheating Help please.
Old Aug 24, 2011 | 07:15 AM
meraj's Avatar
Default Honda Civic 200 Battery Overheating Help please.
Hi,
I recently bought honda civic 2000, 4 doors. the original battery was over overheating, so i bought a new battery and after 3 weeks it started overheating. thanks to costco i could return the battery and get a new one. My question would be why the battery car overheating and what should i change/replace/fix. could it be that it is overcharging?
Thanks so much.
Old Aug 24, 2011 | 07:45 AM
Former User's Avatar
Default Re: Honda Civic 200 Battery Overheating Help please.
Have the alternator tested. It may have a bad voltage regulator that is allowing the system to be overcharged.
Old Aug 24, 2011 | 07:52 AM
meraj's Avatar
I took it to a mechanic and he says just to replace the alternator cost + labour, but not sure if that will fix the problem. How can i test the alternator? Could it be anything else like fuses?
Old Aug 24, 2011 | 08:10 AM
Flar's Avatar
Do you have a multimeter? They're cheap, and it will give you an idea of how much voltage is making it to your battery. With the car running you should get around 14 volts. It very likely has nothing to do with fuses.
Old Aug 24, 2011 | 08:12 AM
Measure voltage across the two battery posts with the engine idling and all electrical accessories off.
tlarimer's Avatar
Take the alternator out and take it to autozone, Napa, etc. most of these chin auto parts stores will test you alternator for free.
tish_86
Classic Hondas
Jun 3, 2014 08:00 AM
adamc44
Mar 19, 2013 10:04 PM
jcar2012
Dec 31, 2012 09:07 PM
duyfash0
Dec 16, 2006 01:10 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
