Transmission & Drivetrain Gearboxes, Differentials, Clutches
Is this bad ??
Old Aug 23, 2011 | 05:48 PM
Hiboost 2.0's Avatar
Icon2 Is this bad ??
delete
Old Aug 23, 2011 | 06:12 PM
Default Re: Is this bad ??
Buummpp for some help please
Old Aug 23, 2011 | 06:15 PM
Fliptard's Avatar
eh, it's somewhat normal, seeings how it's exposed to the weather and being under the car. try cleaning it off with some sand paper and spay some pb blaster or wd 40 to keep the moisture off it and see if it does anything.
Old Aug 23, 2011 | 06:24 PM
.. it should be sticking out that far ? an thanks deff will do
Old Aug 23, 2011 | 06:28 PM
Fliptard's Avatar
Unbolt the whole thing at the car(2 bolts) and see how far it'll go in like that. I'm an H-series guys so this type of shifting linkage I have next delt with.
Old Aug 23, 2011 | 06:40 PM
Fliptard's Avatar
Under the car, where the shifter is is 2 bolts that hold the shifter up in the car, take them out and "shift" it under the car and see if it goes in or out farther than it should, and listen for any wierd noises or knocks.
Old Aug 23, 2011 | 07:24 PM
94EG8's Avatar
Seagull Management
That's normal, however there is supposed to be a boot over that shaft which is why it's rusty. there's also supposed to be a clip around the spring pin for the shift linkage.
Old Aug 23, 2011 | 08:43 PM
thanks.. could u tell me wat the loud clicking could be when puttin it in gear ? or is that normal
Old Aug 23, 2011 | 09:01 PM
Fliptard's Avatar
Noramly it'll make a small click noise when it goes into gear. Some are louder than others... nothing to worry about till it starts popping outa gear or not wanting to go it, then you need new syncros.
Old Aug 23, 2011 | 09:06 PM
Thank u
Old Aug 24, 2011 | 04:31 AM
94EG8's Avatar
Seagull Management
Reverse will normally make a loud click when going in, sometimes first will click but generally not as loud.
Slacker93eg
Aug 13, 2012 05:48 AM
mortificationrock
16
Feb 20, 2009 11:15 AM
RobbieG35
Jul 12, 2006 09:41 AM
Buffs8080
Suspension & Brakes
Mar 7, 2005 09:14 PM
