CRX D16Z6 swap need help
Old Aug 23, 2011 | 12:42 PM
1SickNissan200's Avatar
Default CRX D16Z6 swap need help
helping my brother out with his honda build. not to familar with honda's. been working on suzuki's, nissan's and jaguars for most of my automotive career.
heres the story on the car.
1990 crx si, he blew the engine while racing me. car developed a rod knock. we swapped out the engine with a 95 civic si engine. car runs fine everything is great. just no vtec. i was told to get a OBD 0 ecu for a crx si with vtec.
question is where do i find one ? havent really looked to be honest with u. friend told me this is a great site for honda lovers. im sure i would have to run knock sensor, oil pressure switch and vtec wires once i get the ecu. im not sure if they even came with knock sensors back then.
Please give me ur feedback on this and if u can give me some help that would be great.
thanks, lex
Old Aug 23, 2011 | 01:10 PM
TearSDMF89dx's Avatar
Default Re: CRX D16Z6 swap need help
use the z6 distributor and an obd1 ecu...i have this setup in mine works good
Old Aug 23, 2011 | 01:12 PM
no change in engine harness. can still use the crx si harness ? what kind of computer u running?
Old Aug 23, 2011 | 01:32 PM
p28 ecu and youll need the wiring for the obd1 dizzy... vtec solenoid...and a 4 wire o2 ...jumper harness for the ecu ...im probably forgetting something
4drEF's Avatar
Keyboard Humorist
I guess you could run the B16 PR3. There is an OBD0 version for that.
There is no OBD0 D16Z6 though so you would have to do a 1-wire vtec conversion to the ECU and chip it to make that work. Then your fuel and ignition maps would be off so it wouldn't work proper unless you had it tuned.
Best route is to use the ECU for that engine - a P28. you will need to convert to OBD1 with a jumper harness, distributor, and 4 wire O2 sensor. Everything else is good to go.
I'm curious, when you did the engine swap, what distributor did you put on there? Assuming you have the stock computer as well from the stock CRX motor.
Old Aug 23, 2011 | 01:38 PM
ha...i didnt forget anything....woohoo ...who says weed effects the memory
Old Aug 23, 2011 | 02:31 PM
i used the stock dizzy. i modded it to work. car runs perfectly fine and yeah its stock crx ecu.
thanks for ur help fellas. i think its easier to run a jumper harness from obd 0 to obd 1 and get it tuned. what sucks is my brother is a college study with limited funds. any advise of where to find the jumper harness and p28?
Old Aug 23, 2011 | 02:36 PM
4drEF's Avatar
Keyboard Humorist
If you go with the OBD1 conversion, then you can use the stock D16Z6 ECU and you won't need to tune it.
Old Aug 23, 2011 | 04:24 PM
bprsk8r4272's Avatar
i did the swap in my civic i used the z6 dizzy and p28 ecu cept i didnt use a jumper i wired in the obd1 ecu plugs and modified my engine wire harness
but i would deffinately use the z6 dizzy and p28 ecu along with a obdo to obd1 ecu conversion harness
Old Aug 23, 2011 | 05:13 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yeah there is this website www.eBay.com and they have sellers on there with them listed all the time. Maybe even you could find one at the junk yard...
Old Aug 23, 2011 | 08:15 PM
SFlCrx's Avatar
i used a zerg industries jumper harness. i bought it on ebay with the obd0- obd1 jumper and dizzy jumper. i wired the vtec and 02 wire myself. came with vague instructions lol .
Old Aug 24, 2011 | 01:08 PM
jumper harness and si ecu sounds like the easiest and fastest thing to do. thanks fellas.
Drew Lowe
Jul 18, 2014 04:52 AM
H.crx-si
11
Mar 27, 2004 12:21 PM
Blitzed
Jan 10, 2004 11:58 AM
TiggsCRX
Dec 14, 2003 02:12 PM
SimbaDogg
14
Nov 28, 2003 10:49 AM
