A/C pipe connections
So, I'm nearing the end of the A/C rebuild, and I can't seem to get the system to hold a vacuum. I can get it up to 25inHg of vacuum with my pump now, but when I close the valve, it leaks back down to 0. I connected and torqued the connections to spec. (I had to guess on the connections with too little space to permit my beam wrench.)
I have attempted to locate the leak by stethescope, but that didn't get me very far. I added UV dye, so once I get it close to sealed, I can use that to find any slow leaks, but I need a method for the current state. Obviously, if I had access to dry Nitrogen, this would be a non-issue, but I'm not ready to pony up $120 for a regulator.
Any suggestions for locating the leak that doesn't involve venting large quantities of R-134a into the atmosphere?
Thanks in advance.
Thanks in advance.
Yes, but the R134a will escape rapidly through the leak - and I will probably resort to that, but I was looking for a more elegant solution.
Should I replace the drier *again* because the system was not been completely sealed when I installed it the first time? (After all of the leaks are located, of course) Or, should I wait to see if there is a moisture problem?
Thanks
Thanks
parsapour
Apr 28, 2018 08:57 PM
drumminforev
Feb 3, 2006 08:06 AM
