Gettin' Skunk2 stage 2 Cams...What ECU should I run???
Old Oct 3, 2002 | 03:22 PM
AK94GSR's Avatar
Default Gettin' Skunk2 stage 2 Cams...What ECU should I run???
I plan on getting stage 2 cams from skunk, but I am still thinking about what ecu chip I should get. I think I'm in a toss up between a jdm ITR ecu or a skunk2 chipped ecu. I have heard that the skunk program runs really rich and being that I live no where close to a dyno where I could tune it in more with a vafc then I am kind of going for the easist route as far as tuning goes. In other words I don't want to run into any problems with one of these for my set up.
anyone got any suggestions please help
Old Oct 3, 2002 | 03:33 PM
Malice's Avatar
New User
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (AK94GSR)
get the skunk chip.
Old Oct 3, 2002 | 04:24 PM
Spyderwebab's Avatar
I think the easiest way to go would to get hondata and tune it...think about it...$250 to chip your ecu and then $300 for a VAFC...
Now Hondata uses your ecu and its better than a vafc all in one...for $295....
Now you think about it....
Old Oct 3, 2002 | 04:40 PM
-Whitey-'s Avatar
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (Spyderwebab)
where can i get info on the hondata?
that seems like a good deal even though i allready have the v-afc
Old Oct 3, 2002 | 04:42 PM
AK94GSR's Avatar
Well yeah I did think about Hondata, but like I said I have no way of tuning my car except on the street. Plus with hondata, wouldn't I have to get the complete package so I would be able to tune and chip my own ecu. I'm still not quite understanding how the stages of hondata works.
I just want an ecu that would require little tuning on my part but still have good gains.
Old Oct 3, 2002 | 05:08 PM
-Whitey-'s Avatar
if i were you id stick ith skunkworks and get thier chip for your ecu
Old Oct 3, 2002 | 06:15 PM
D.Lansing's Avatar
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (One Honda)
better save up for some new rocker arms too
Old Oct 3, 2002 | 10:17 PM
AK94GSR's Avatar
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (D.Lansing)
What's this about rocker arms???
I thought it's only the stage 3's that have this problem.
explain
Old Oct 3, 2002 | 10:30 PM
John-GSR's Avatar
I hope that you're getting the valve springs and all that relateed stuff too. My advice, if you plan to do more work get Hondata. Find a shop to tune everything. Proper tuning is the best no mater what.
Old Oct 4, 2002 | 03:50 AM
D.Lansing's Avatar
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (John-GSR)
I just hear of A LOT of people that come on this board and say that the skunks ate their entire valvetrain (regardless of spec of cam). I don't usually accept rumors, but when you hear something enough, that is proof for me that its happening. Like crowers snapping.......
Old Oct 4, 2002 | 04:10 AM
dirtyazn's Avatar
ya mang you need valvetrain with the skunk stage 2's
the skunks stage 2's and 3's are just like JUN 3's and Toda spec B and C's
you need the whole shabang if your gonna run those...
not for someone who can't make it to a dyno
Old Oct 4, 2002 | 08:51 AM
AK94GSR's Avatar
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (dirtyazn)
I have already prepared for that, when I sent my head off to PYR I had them install Type R intake valves, dual valve springs, Ti retainers and new valve seals. So my head is good to go the only thing I may need is just more compression.
Old Oct 4, 2002 | 01:36 PM
b19coupe's Avatar
What valve springs are you running ? You will need Skunk2, Portflow, or other aftermarket valve springs-stock Type-R springs not up to the task.
Old Oct 4, 2002 | 03:02 PM
AK94GSR's Avatar
Default Re: Gettin' Skunk2 stage 2 Cams...What ECU should I run??? (b19coupe)
They are an aftermarket valve spring but can't remember the name. I'm emailing Peter so I can find out. He said they can run JUN3's with no problems and can rev to about 9600rpms. So I know they are up to task since that is why I got them and peter said he has no problems with any cams.
About the ECU, so you think I should just go with the skunk2 chip since they are made for the cams. But I see alot of R guys with these cams stages 1 and 2 and they are getting good numbers with their stock ecu.
1hotintegra
Jun 29, 2003 03:24 PM
AK94GSR
May 28, 2003 02:01 PM
Audipwr1
Oct 16, 2002 08:38 AM
fred92htch
Sep 6, 2002 01:29 PM
