Fuel pump not turning on
Old Aug 22, 2011 | 03:12 PM
brian91accord's Avatar
Default Fuel pump not turning on
I have a 91 accord. My fuel pump is not turning on when i turn the ignition. I changed the main relay and that didnt fix it. I checked all the ground and cleaned them up. I checked all the fuses and all are good. When i jump 5 & 7 the pump comes on, so i know its good. I am running out of ideas here. Anyone have any ideaS?
Old Aug 23, 2011 | 03:38 PM
poorman212's Avatar
Default Re: Fuel pump not turning on
You are jumping 5 and 7...from the wire side?
Pos to #4 and neg to #8 on the relay, is there continuity from 5 and 7 on the relay?
Old Aug 24, 2011 | 01:32 PM
i am doing it while the relay is plugged in. I bought another relay for the hell of it and it didnt fix the issue.
Old Aug 24, 2011 | 02:34 PM
so now when i changed the relay i have no fuel or spark. My coil is getting power. My pump reads power when i jump 5 & 7. When i don't jump it the pump has no power. I took the ground off of the thermostat and the CEL turns off..
Old Aug 25, 2011 | 11:59 AM
bdmlilburn's Avatar
the ground on the thermostat is the ecu ground which is why the cel goes away. make sure that ground is nice and clean and tight along with the transmission to frame ground and the motor to frame ground next to the drivers side mount.
where did you get your main relay? i had a starting problem with my prelude and got a main relay from autozone. it made the fuel pump not work sometimes and then eventually didnt work at all. problem was fixed by removing the main relay from my 90 accord and plugging it into the prelude
Old Aug 25, 2011 | 04:18 PM
straight from honda.
hondaluver12
Jan 30, 2012 02:37 PM
4banger1986
Nov 26, 2008 02:42 PM
ALL MOTOR DA
35
Aug 18, 2006 09:44 PM
0817crx
Sep 18, 2005 08:00 AM
wpgcivic
Dec 7, 2004 05:44 PM
