Removing rear view mirror
Old Aug 22, 2011 | 03:11 PM
highmfer's Avatar
Default Removing rear view mirror
This is for everyone who has a rear view mirror that is attached to the windshield without a set screw to hold it in place. I've included pictures to help because I'm not the best at putting thoughts into words.
Hopefully this helps because in know I had a hard time to find clear instructions on how the mirror itself was attached to the metal peice on the window.
1st off you need a very small flat head screw driver or I used a 3mm alan key. Make sure your mirror is as far down towards the dash, as possiable. Insert the alan key into the hole at the bottom of the mirror bracket, on a angle so it points to the center.
Push the alan key (hard) to bend the retainer clip inside. As you push the clip aside, pull upwards on the mirror to remove it from the metal clip on the window.
The following are pictures of the retainer clip inside the mirror and clip attached to window. Note the cracks in my window were from b4 and were not made worse by removing the mirror.
Hope this is useful for anyone doing a wink install or just trying to fix their stock mirror.
Old Mar 28, 2012 | 04:15 PM
CjkPHD's Avatar
Default Re: Removing rear view mirror
What is that piece that is glued to the windshield? The portion that the rear view mirror hangs off of? I need the part no. because someone decided to steal my sol and rip off the damn thing.
Old Apr 24, 2019 | 07:04 PM
1993 SI 400k's Avatar
Thank you to the OP. After 26 years the dimmer wore out on my mirror. I got a junk yard one from ebay for $30, and it had part of the windshield still attached. I guess they couldn’t figure out how to remove it, Too bad they didn’t read this post first. It took me less than five minutes once I had this post in front of me.
Old Jan 3, 2026 | 10:25 AM
Kein_Internet's Avatar
this is a shot in the dark and kind of a weird ask but OP do u perhaps have a clearer image of the metal circle connecting the main body of the mirror to the arm or any information about how it is connected?
I want to remove my mirror from the arm without breaking it but haven't been able to find any information about that anywhere.
G'Funk
Mar 3, 2008 01:37 PM
ianae86
Jan 8, 2006 06:01 PM
TimJay
Dec 21, 2005 08:18 AM
DBOT
May 13, 2005 05:14 PM
