Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Special Sale! Omni Power Map Sensors
Old Aug 22, 2011 | 10:42 AM
LogicMotorsports.com's Avatar
Default Special Sale! Omni Power Map Sensors
WE WILL MATCH ANYONE'S ADVERTISED PRICE
We carry 2.5, 3, and 4 Bar Map Sensors (Please specify which one you want)
--------------------------PM FOR LOWEST PRICE-----------------------------
Description:
DIRECT PLUG AND PLAY!!!
Omni Power MAP (Manifold Absolute Pressure) sensors use state of the art bipolar op amp circuitry with thin film resistor networks built into each micro chip. Pressure changes are calculated on a true linear 0-5 volt scale via a specially designed silicon pressure sensor that also compensates for temperature changes. The unique ability to compensate for temperature changes allows the Omni Power MAP sensor to remain a minimum of 99% accurate from 32 degrees F to 180 degrees F through out its range of scale.
With the true linear pressure vs. voltage scale there is never a need to re-tune at different altitudes as with other sensors. Competitor's sensors on the market do not have true linear scaling which can cause your engine to go out of tune with elevation changes, often resulting in idle problems and catastrophic engine damage. Omni Power MAP sensors can precisely calculate boost pressure from 1-43+ psi while allowing smooth stock OEM drive ability at any boost level. Conveniently packaged in an OEM dimensional housing for easy install and an OEM look.
Will work with Hondata S100/S200/S300, Crome, eCtune, Neptune, Uberdata, AEM EMS, APEXi Power FC and any other ems that can input map sensor data.
Check us out at www.logicmotorsports.com
Follow us at www.facebook.com/logicmotors
Old Aug 23, 2011 | 09:08 AM
Default Re: Special Sale! Omni Power Map Sensors
good morning. all pms replied.
Old Aug 24, 2011 | 08:11 AM
all pms replied.
Old Aug 25, 2011 | 08:08 AM
good morning and thanks for all the orders.
Old Aug 25, 2011 | 11:38 AM
whats for lunch?
Old Aug 26, 2011 | 09:01 AM
all pms replied. Thanks for inquiring with logicmotorsports.
Old Aug 29, 2011 | 09:42 AM
back from the weekend. all pms replied.
Old Aug 30, 2011 | 12:23 PM
all orders have been shipped.
Old Aug 31, 2011 | 08:24 AM
thanks for the orders. all pms have been replied.
Old Aug 31, 2011 | 12:58 PM
all orders shipped.
Old Sep 1, 2011 | 09:50 AM
all pms replied.
Old Sep 2, 2011 | 09:08 AM
all pm's replied.
Old Sep 4, 2011 | 03:59 PM
all pms replied.
Old Sep 5, 2011 | 09:07 AM
all pms replied.
Old Sep 5, 2011 | 11:54 AM
2xraeted's Avatar
price for 4 bar map sensor shipped to 32164
Old Sep 5, 2011 | 02:53 PM
all pms replied.
Old Sep 5, 2011 | 05:23 PM
SOUNDEFFECTS's Avatar
Price on 4 bar K series sensor please.
Old Sep 6, 2011 | 09:15 AM
all pms replied.
Old Sep 6, 2011 | 02:32 PM
all orders shipped.
Old Sep 7, 2011 | 09:46 AM
all pms replied.
Old Sep 8, 2011 | 09:09 AM
all pms replied.
Old Sep 9, 2011 | 08:33 AM
all pms replied.
Old Sep 12, 2011 | 08:49 AM
Hope everyone had a great weekend. All pms replied.
Old Sep 13, 2011 | 10:54 AM
all pms replied.
Old Sep 14, 2011 | 09:48 AM
all pms replied.
