Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Turbonetics SALE!!!(Turbos, Wastegates, BOV's)...
Old Aug 22, 2011 | 10:08 AM
LogicMotorsports.com's Avatar
Default Turbonetics SALE!!!(Turbos, Wastegates, BOV's)...
WE WILL MATCH ANYONE'S ADVERTISED PRICE
Everything and anything you need that is Turbonetics...We have!!!...ON SALE!!!
----------------------------PM FOR LOWEST PRICE---------------------------
Visit us at www.logicmotorsports.com
Follow us at www.facebook.com/logicmotors
T3 Series:
The T3 is the smallest family of turbochargers that Turbonetics offers. Perfectly sized for applications under 2 liters, the T3 line-up starts with the 150 HP 35 trim wheel and goes up to the 325 HP Super 60. T3 compressor wheels are efficient up to 22 psi.
T3/T04B series:
The T3/T4 Hybrid turbochargers consist of a T3 turbine section, (F1-49, F1-54, F1-57, F1-62) and a T4 compressor section (T04B trim, T04E trim & 60-Series). This combination offers the low inertia and fast boost response of the lightweight T3 turbine wheel and the high-airflow characteristics of the T4 compressor family.
T3/T04E series:
Looking for more power? Search no more. The tried-and-true combination of T04E series allows you to achieve big power while retaining compact packaging. Turbonetics T04E compressor wheels are extremely effective on high pressure applications. Match it with Turbonetics Patented Ceramic Ball Bearing and you get a monster result! With its larger compressor housing (compared to T04B) and 3” compressor inlet, T04E is able to deliver the power you desire.
T04B series:
The T04B series turbochargers are one of the most versatile units available to the performance aftermarket. High compressor efficiency, strict quality standards, Turbonetics’ exclusive “blue printed” assembly process and competitive pricing makes the T04B the obvious choice for many applications.
T04E series:
The T04E series allows you to achieve big power while retaining compact packaging. Turbonetics T04E compressor wheels are extremely effective on high pressure applications. Match it with Turbonetics Patented Ceramic Ball Bearing and you get a monster result! With its larger compressor housing (compared to T04B) and 3” compressor inlet, T04E is able to deliver the power you desire.
Wastegates:
Evolution
Nearly 25% smaller than the DELTAGATE it is sized to fit into the tightest turbo systems. Fitted with a rolling type diaphragm and floating valve seat it is equipped to comfortably handle 400+ HP and out flows the competition by almost 20%. New for 2009 - adjustable set screw in wastegate cap now standard. Flat top design is now discontinued.
RG-45
The brand new RG-45 replaces the legendary Racegate in our wastegate lineup. Built with the latest technology such as stainless steel base, inconel high temp valve, high temp fluro-silicone diaphragm, and v-band connections all in a very small frame size. Like its name suggests, the gate has a 1.77''/45mm valve and is good for powerplants making up to 750 HP.
Blow Off Valves
Duo-35 Polished or Gunmetal
This exclusive blow-off valve features a dual cross tunnel discharge system with various discharge designs. You can use one or two GT-K inspired horns to vent the pressurized air directly to atmosphere for that extra loud discharge. Without the horn, you can recirculate for tuning purposes and quieter operation.
Godzilla
A totally unique design! The “Godzilla” bypass valve assembly offers the ultimate in surge protection and cosmetic appeal. Highest flow capacity available - bar none! Aircraft-quality construction featuring a 1.8" (45mm) diameter all stainless steel valve assembly and a totally sealed actuator assembly. All polished aluminum with a unique V-band mount that allows a full 360-degree orientation. Includes 2" diameter discharge for system connection and weldable steel alloy and aluminum mounting flanges.
Old Aug 23, 2011 | 09:08 AM
Default Re: Turbonetics SALE!!!(Turbos, Wastegates, BOV's)...
good morning. all pms replied.
Old Aug 24, 2011 | 08:11 AM
all orders shipped.
Old Aug 25, 2011 | 08:08 AM
good morning and thanks for all the orders.
Old Aug 25, 2011 | 11:38 AM
whats for lunch?
Old Aug 26, 2011 | 09:02 AM
all pms replied. Thanks for inquiring with logicmotorsports.
Old Aug 29, 2011 | 09:39 AM
back from the weekend. all pms replied.
Old Aug 30, 2011 | 12:26 PM
thank you for all the orders.
Old Aug 31, 2011 | 12:59 PM
back from lunch.
Old Sep 1, 2011 | 09:52 AM
all pms replied.
Old Sep 2, 2011 | 09:09 AM
all pms replied.
Old Sep 4, 2011 | 04:00 PM
all pms replied.
Old Sep 5, 2011 | 09:09 AM
all pms replied.
Old Sep 6, 2011 | 09:08 AM
all pms replied.
Old Sep 6, 2011 | 02:33 PM
all orders shipped.
Old Sep 7, 2011 | 09:37 AM
all pms replied.
Old Sep 8, 2011 | 09:08 AM
Old Sep 9, 2011 | 08:32 AM
all pms replied.
Old Sep 12, 2011 | 08:48 AM
Hope everyone had a great weekend. All pms replied.
Old Sep 13, 2011 | 10:55 AM
Old Sep 14, 2011 | 09:49 AM
all pms replied.
Old Sep 15, 2011 | 10:15 AM
all pms replied.
Old Sep 16, 2011 | 07:40 AM
all pms replied.
Old Sep 16, 2011 | 01:45 PM
all turbo chargers shipped.
Old Sep 19, 2011 | 10:43 AM
Back from the weekend. All pms replied.
