Suspension & Brakes Theory, alignment, spring rates....
Honda Civic 2000 Si Lowering Question.
Old Aug 22, 2011 | 08:36 AM
RetroGamer's Avatar
Default Honda Civic 2000 Si Lowering Question.
I have 16x7 inch rims with 205/45's on them. I was looking at a kit that drops the ride 1.6 inchs would that work? Or do i need coil overs? I don't really want to get coil overs but don't want to order the kit and find out that don't fit.
Old Aug 22, 2011 | 08:37 AM
deadbeatandrew's Avatar
Default Re: Honda Civic 2000 Si Lowering Question.
how low do you want to go? if you only want to go "1.6" then that will work..
Old Aug 22, 2011 | 08:44 AM
grumblemarc's Avatar
The Grumpiest
Progess CS-IIs. 350f/35o/r with shortened shock body gives you an AUTOMATIC 1" drop.. I highly recommend them. There's a reason they are currently sold out. With plain old springs you won't ever sit square on all four corners.
Old Aug 22, 2011 | 12:22 PM
RetroGamer's Avatar
It was the eibach sport shocks and springs set-up. It's a 1.6 inch drop all around.
Eibach Springs
Model: Sport-System Kit
Details: Incl. Sportline Springs/Pro-Damper Shocks; Front w/1.6 in. Drop And Rear w/1.6 in. Drop;
Old Aug 22, 2011 | 12:34 PM
98civdx's Avatar
Master Detailer
What do you mean will they work?
Don't ever base your suspension setup on the wheels you have, there's no point to.
If you order coilovers for your car you will be fine. (Unless you buy shitty coilovers) They are adjustable so you are able to rasie and lower the car as you wish, with lowering springs you cannot do this.
The eibach system will work.
Old Aug 22, 2011 | 06:54 PM
RetroGamer's Avatar
I know how coilovers work but my rims and tires are almost new and i don't want to buy coil overs. I want to buy shocks and springs and don't want to get them in and install them then the 1.6 won't fit like it sits to low for the rims and tires.
Old Aug 22, 2011 | 07:16 PM
98civdx's Avatar
Master Detailer
So than get springs with a different drop.
flyingduck04
Suspension & Brakes
Feb 24, 2012 12:32 PM
integra-sena
Suspension & Brakes
Mar 11, 2009 04:35 PM
messeduprex
14
Apr 10, 2007 11:06 AM
vestalfootball72
Suspension & Brakes
Jun 7, 2006 05:00 AM
NetRyderz
27
Feb 5, 2004 12:34 AM
