transmission oil?
go to any honda/acura dealership for the MTF (manual transmission fluid) or regular 10-30w engine oil.
others (like my self) have used Pennzoil syncromesh, and that works fine.
*also, standard amount is 2 quarts.
OP, drain the trans, plug back up, remove the vss at the rear of the trans, use a long funnel and pour in two quarts of mtf/oil/syncromesh and pop the vss back in. You're done.
