Del Sol Passenger Window Problem
93 Del Sol
The Driver side and rear window work fine.
The passenger windows likes to randomly work. It is not b/c of the window lock button either.
When the window does work, only the switch on the drivers side can roll it down, otherwise the switch on the passenger side is completely dead. I decided to disconnect the switch on the passenger side to see if it changed anything. It would still randomly stop working.
So, could it be the main Power Window Switch on the driver side? Can a faulty driver side switch affect the passenger side regulators function?
It's not the passenger windows motor since it rolls the window up fine and doesn't stutter, or appears to be weak.
I rather not bring this to the dealer, since I think it might be a simple fix. I did replace the fuses and that did not fix the problem either.
Thanks
Thanks
del_sol 2009
11
Apr 21, 2009 01:55 PM
deconstruct
Apr 12, 2005 08:43 PM
