sensor help please
Old Aug 21, 2011 | 08:53 AM
boostNjuice's Avatar
Default sensor help please
Ok so the harness im dealing with is a MESS. id love to buy 1 for my 88 crx si but tough times calls for shitty decisions lol so heres my problem
Im running a b18 from a DA integra the fan switch is located on the back of the motor and the harness is different to me cuz im used to dealing with 92-00 harness's. question is how can i get this fan either to stay on or come on by command.. which color wires do i need to look for to tie together because most of the clips are broken/ cut off.
2nd what color is the single wire for the temp gauge and if i dont have it cuz its been cut how can i run it straight to the ecu and what not. thanks!
Old Aug 21, 2011 | 09:50 AM
apexi_rsx's Avatar
Default Re: sensor help please
should be a green and yellow wire . you can wire it either way which will tell the fan to push or pull. when u hook it up test the fan before finalizing and splicing the wires together. Engine coolant temp sensor should be located on the head by the dizzy and is a white and red wire i believe. the sensor closest to the front of the car.
Old Aug 21, 2011 | 09:53 AM
virgineg6's Avatar
Are you in the right section?
Old Aug 21, 2011 | 10:49 AM
whats it matter to you dude, dont get your panties in a bunch, if the mods are not tripping what the hell are you thinking. and FYI this is a electrical related tech question thats not really specific to the car cuz pretty much all 88-00 civic/crx/integra/accord share similar harness's
Old Aug 21, 2011 | 11:32 AM
grumblemarc's Avatar
The Grumpiest
Now you're in the right section.
Old Aug 21, 2011 | 11:42 AM
crx_si-r's Avatar
pm me if you need a stock harness, i make them.
Old Aug 21, 2011 | 11:56 AM
Monko's Avatar
I grounded the yellow and hooked the green up to a toggle switch for it to pull. Didn't know I could reverse it.
mr. carpenter
Jun 13, 2005 04:03 PM
scrubachu
Aug 28, 2004 11:38 AM
scrubachu
Aug 28, 2004 07:21 AM
