All Motor H22a???
Old Aug 21, 2011 | 08:36 AM
js97f22b's Avatar
Default All Motor H22a???
hey guys im looking to build an all motor coupe and need some suggestions. i was thinking about using an H22a, with a fully built bottom end and mild head work. would like to achieve at least 250 to the wheels. basically just wondering if this would be a good route and if i could get some good hp numbers? any other engines that woud be better to start with? ive just been doing some research and trying to get some good times possibly high 12 or low 13s the faster the better haha, the most cost effective way. Any suggestions would be great, thanks
Old Aug 21, 2011 | 09:12 AM
mafia's Avatar
Default Re: All Motor H22a???
If I was in your shoe's... I would call a known good shop, that you will have do your motor build. Be ready to spend a lot of money. H22 block you will most likely need to sleeve, unless you are going to use your F22 block.
Blown99sh
Dec 31, 2014 07:35 AM
brown11
Apr 25, 2009 08:58 AM
E9CiViC1F
Jan 17, 2009 04:53 PM
btrim23
Mar 22, 2005 12:04 PM
H22A_HB
Dec 13, 2004 11:59 AM
