Where to lift a b18c1
Old Oct 3, 2002 | 01:50 PM
HybridHatchC1's Avatar
Default Where to lift a b18c1
where are the jack pionts on the engine so i can put it in this weekend, its almost done just need to get the skunk2 manifold and drop it in.
i wish i had a camera the hatch looks funny, completely gutted interior,no engine or front end. kinda like a going through the assembly line from honda. should be done sunday then i will post pics
Old Oct 3, 2002 | 03:14 PM
poison's Avatar
Default Re: Where to lift a b18c1 (Civ-JDM)
most people put a bolt in where the power steering threads are and use that power steering bolt and put the chain on that, as well as a tranny bolt.
Old Oct 3, 2002 | 03:53 PM
Slurp56's Avatar
Default Re: Where to lift a b18c1 (poison)
There should be hole in the bracket on the top of the tranny, I usually stick a bolt through there and screw a nut on the other side. The 2nd lift point I use is either the P/S bracket, motor mount bolt, or there is a threaded hole on the back of the block next to the intake manifold. That threaded hole is there so you can bolt an engine lift bracket (hook) there.
djkina
Dec 27, 2014 07:10 AM
theidealone
Nov 27, 2010 07:45 PM
91EF919
Mar 21, 2009 05:13 PM
dat_flip
Sep 2, 2004 05:30 PM
216.226.142.95:27016
Jul 3, 2003 10:20 PM
