Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2003 Acura 3.2TL Transmission Failure
Old Aug 20, 2011 | 08:33 AM
pt2903's Avatar
Icon2 2003 Acura 3.2TL Transmission Failure
Hi, I have 2003 Acura 3.2TL with 72000miles,yesterday when i was driving i see jerks while shifting the gear from 1st to 2nd and then runs normally.I know there was recall in 2004 and Moreover i am new owner of this car..I don't know whether the previous owner fixed the transmission or not...what i am supposed to do now...
Any one please help me out...
Old Aug 22, 2011 | 05:10 AM
civichxtreme2's Avatar
Default Re: 2003 Acura 3.2TL Transmission Failure
Unfortunatly its a common problem with the TL's 2nd gen and 3rd gen, I would first attempt to call an Acura service center and cite the recall and explain your issue, they may be able to help, if not you may just have to bite the bullet and handle it yourself. If thats the case I would first try a proper flush and see if it helps any, if not you may end up having to replace the unit.
Old Sep 18, 2011 | 03:18 PM
Blamm!!'s Avatar
your 1-2 and 2-3 clutch packs are probably toast and you need a rebuild. It happened on our 2003 TL and 110,000 miles.
Old Sep 18, 2011 | 07:29 PM
slomofo's Avatar
GDD Member
Transmissions are junk on those cars, common problem... sad, but true.
Old Oct 6, 2011 | 06:38 PM
russo1994's Avatar
agreed...
pk4355
Acura TL, RL & ZDX
44
Feb 15, 2018 02:18 PM
ladylbc
Acura TL, RL & ZDX
Feb 24, 2010 05:27 PM
dashark
11
Jan 28, 2004 07:07 PM
