IL }FS: 1996 White Turbo EK hatch/ FULLY BUILT/ CLEAN{
Old Aug 20, 2011 | 08:06 AM
Hellspawn's Avatar
Icon5 }FS: 1996 White Turbo EK hatch/ FULLY BUILT/ CLEAN{ $10k - OBO!
Updated 6/14/12
-->FOR SALE
-NO parting out!
-Possible trade for clean RHD car
$10K - OBO
Contact info = eshady84@gmail.com
Or PM me with any questions
Or text me @ 224-522-0287
Up for sale is my prized possession. I never thought I'd do this but its for the best. I have owned this car for about 6 years now and now its time to let it go and start with something new/ different. I have built this car from the ground up, it took about 1.5 years to complete. The engine was broken in properly for 500 miles before it was dyno-tuned. I have ALL of all receipts of all the things purchased for this build (About $12,000 in mods alone). Engine was dyno-tuned at KING Motorsports and put down 326HP / 261 Torque @ only 18psi with stock cams. My intention was to have it tuned at 24psi but since I am not using a strong enough clutch, it was slipping on the DYNO and so we brought it down to 18psi. SO... there is definitely more room for power. Just get a stronger clutch and upgrade from the stock cams, you'll definitely get more power with ease. This car has been taken care for and always has been garaged. It has never seen snow or rain since I've own it. The oil changes have been done every 4-5 months, very low mileage oil changes with OEM Honda filters and Mobil1 Syn oil. I barely drive it and when I do, its always been good to me. Drives great, pulls hard, there are no problems whatsoever. In fact I turned down the boost to 15psi to make it more streetable. Whoever ends up with this hatch will be extremely pleased. It is a definite eye catcher, always getting props from random people. One of the cleanest hatches out here.
The reason I am selling this beauty is because I've recently bought a house and I have been concentrating more on the house than my hatch. Ever since the move, I have only driven it a handful of times. I am trying to stay low key but I have grown tired of being paranoid of thieves. I've been a victim of a stolen car before and I do not want to re-live that moment. So, I think its best to see if anyone is interested in picking up my hatch and then I can focus on my house.
*I am reasonably asking for $10,000 O.B.O. CASH ONLY (considering parts are over $12,000 and that doesn't include the price of the car, paint, tuning, etc.) **No test drives unless money is in hand (we've all heard stories of what has/ can happen)
Ok, heres the list, I'm sure I'm missing a couple small items but theres too much to write down. Pics are below, what you see is what you get. If you have any questions, let me know and Ill answer them as best as possible.
->1996 Honda Civic DX Color : Grand Prix White (originally red)
Mileage : 125,000 miles*
Title : Clean (in hand)
->Engine/ Head (2,9xx miles on built motor)
B18b block built by Exospeed (Stage 4 Block)
Arias pistons / 9:1 compression Eagle rods OEM Honda oil pump (GSR)
OEM Honda bearings Bore, hone, hot tank and step deck (bored to 2.0)
Micropolish crank
B18b (LS) head built by Opel
Stock LS cams
Ferrera valves and springs
Ported runners
AEM adjustable cam gears
Garrett turbo (T3/T4 57 trim)
Spooling Performance Ramhorn turbo manifold
Turbonectics Evolution wastegate
Custom 3" downpipe to cat-back
Vibrant Turbo 3" cat-back
PLX Wideband AFR
Hondata S300 with boost P28 ecu
Biltz blowoff valve
Turbosmart adjustable boost controller
Evo 8 front mount intercooler
BBK 70mm throttle body
780cc Precision Turbo injectors
B&M fuel pressure gauge (on rail)
AEM fuel rail
AEM adjustable fuel regulator
AEM intake filter
NGK spark plugs and wires
GM 3bar map sensor
Hasport Mounts
Moroso oil catch can breather
Koyo radiator
10" cooling fan
Magnetic drain plug -
>Transmission Type R transmission (stock LSD)
Type R shift linkages
ACT Xtreme pressure plate
ACT Xtreme clutch (full face)
ACT Lite flywheel
OEM honda fluid
Magnetic drain plug
->Suspension/ Rollers
Spun 15" wheels/ gold (RPF1 replicas)
205/50R15 Falken Azenis
Omni coil-overs
Rear disc conversion
Braided steel lines
Brembo slotted front and rear discs
Hawk brake pads
Polyurethane rear trailing arm bushings
Avid Traction bar
Benen front tri bar
Skunk2 front adjustable control arms
Skunk2 rear camber arms
Omni rear LCAs (gold)
Lower rear tie bar (ebay)
Rear strut bar (ebay)
->Interior
Sparco Speed seats
Sparco seat rails and sliders
Sparco seat harness (3-point)
Sparco steering wheel with red honda horn button (wired/works)
Momo steering hub
Greedy turbo timer
Si cluster (actual mileage on built motor)
Spoon shift ****
Honda amber clock
Autometer 52mm gauges (boost, water temp. and oil pressure)
Panasonic head unit with iPod interface
Alpine type R 6.5 front component speakers (tweeters mounted in door panels)
Honda type R shift boot (OEM)
->Exterior
'99 front end conversion
Black headlights
Front Si lip
Rear Si lip (not installed)
Antenna delete
Rear wiper delete
Spoon side mirrors (replicas)
Amber fender sidemarkers
*The bad… -Once I purchased the vehicle back in 2005, I was told that the mileage on the DX cluster was original (76802 miles) to the car. Either the owner before me lied or he wasn't sure himself but the mileage was not correct. So when I registered it at 76802 miles, it threw a flag on the CARFAX that the mileage is incorrect. Everything else about the car is clean, no accidents or theft, etc. So with that in mind, when I started the build, I sold the DX cluster on eBay and then bought a Si cluster with 0 miles on it (so I can keep track on milage on the NEW built motor), I was skeptical at first but the seller insured me that it was legit/ was not rolled back. Once I finally finished the build and started to put miles on the engine, I immediately noticed that the speedo does not read correctly. It reads 10 mph higher than normal. I bitched and complained about it to the seller and no response was made. So the seller received negative feedback from me and thats that. Long story short, the cluster reads the correct amount of miles on the NEW/BUILT motor, not the vehicle itself. According to the CARFAX, vehicle has about 125,000 miles on body.
- Also, since I never drive this hatch anymore, I haven't renewed the plates and as of now, the plates are suspended..
- Interior is gutted and has no A/C
Last edited by Hellspawn; Jun 14, 2012 at 07:33 PM. Reason: Re post, up for sale again
Old Aug 20, 2011 | 08:28 AM
Hellspawn's Avatar
Default Re: }FS: 1996 White Turbo EK hatch/ FULLY BUILT/ CLEAN{
Pics recently taken...
Old Aug 20, 2011 | 09:05 AM
speedy666's Avatar
flawless.glws
Old Aug 21, 2011 | 12:58 PM
Hellspawn's Avatar
Originally Posted by speedy666
flawless.glws
Thanks... very much appreciated.. BUMP
Old Aug 21, 2011 | 01:32 PM
Tarzan's Avatar
Job well done
Old Aug 21, 2011 | 05:23 PM
Fibercation's Avatar
Fresh
Old Aug 22, 2011 | 07:29 AM
Hellspawn's Avatar
Originally Posted by Tarzan
Job well done
Thank you..
Old Aug 22, 2011 | 07:30 AM
Hellspawn's Avatar
Originally Posted by Fibercation
Fresh
Thanks for looking...
Old Aug 23, 2011 | 09:55 AM
Hellspawn's Avatar
Tuesday lunch bump....
Old Aug 26, 2011 | 07:03 PM
Hellspawn's Avatar
BUMP....
Old Aug 30, 2011 | 02:53 AM
Hellspawn's Avatar
Tuesday mornin bump...
Old Sep 2, 2011 | 04:03 AM
Hellspawn's Avatar
TGIF bump...
Old Sep 2, 2011 | 05:43 PM
Hellspawn's Avatar
Whoops, forgot to add this pic...
Old Jun 10, 2012 | 02:16 PM
Hellspawn's Avatar
Icon5 Re: }FS: 1996 White Turbo EK hatch/ FULLY BUILT/ CLEAN{
OK summer is finally around the corner. I am back and willing to try this again. UP FOR SALE PEOPLE....
Please bump if viewed
Old Jun 11, 2012 | 12:16 AM
anthonysed3's Avatar
bumping. GLWS! Great car!
Old Jun 12, 2012 | 05:11 AM
Hellspawn's Avatar
Thanks, I really appreciate it! Morning bump
Old Jun 14, 2012 | 07:34 PM
Hellspawn's Avatar
Watching the OKC v. Heat game bump...
Old Jun 16, 2012 | 11:45 AM
TypeRfit's Avatar
RESIDENT
I like how you kept it real with non vtec turbo. I like it. GLWS
Old Jun 16, 2012 | 07:57 PM
B18CUL8R's Avatar
clean car...glws
Old Jun 17, 2012 | 10:03 AM
Hellspawn's Avatar
@B18CUL8R + typerfit = Thanx for the support, much appreciated.
Sunday BUMP..
Old Jun 20, 2012 | 11:29 AM
Hellspawn's Avatar
wednesday bump
Old Jun 20, 2012 | 04:15 PM
joeitovtec69's Avatar
trade
http://hondamarketplace.com/showthread.php?t=3062717
Old Jun 21, 2012 | 12:02 PM
Hellspawn's Avatar
Originally Posted by joeitovtec69
PM'ed
Old Jun 28, 2012 | 05:44 AM
Hellspawn's Avatar
what up HT? Thursday morning bump..
Old Jul 7, 2012 | 01:40 PM
Hellspawn's Avatar
The weekend bump
DoNDoNJJJ
Jun 17, 2009 08:22 AM
dizzyroc88
Jul 7, 2008 03:56 PM
VTECth1s
Aug 12, 2006 11:02 AM
diputs
May 24, 2004 10:07 PM
