Built H22a Turbo Partout. Precision, Lovefab, Tial, etc
I sold the shell that had my H22a in it. Gonna sell everything else that was in the engine bay along with gauges, wb, etc. Just txt me at 828 850 5974 and tell me your username on here and post in this thread saying txt sent or something so ill be able to PM you if needed without having to search your name. Will send pictures through txt, all parts are at my friends shop so if im not there just give me a day or 2. Motor/turbo/tial and a few other small pieces have less than 500 miles.
Built H22a, Darton Mid sleeves, .0040 over (88mm bore i believe is what it comes to) Eagle Rods/Wiseco pistons, 8.5:1 Compression, all bolts are ARP except mains. No balance shafts. MLS Head gasket. Head is the matching head for the motor, Skunk2 Tuner T1 cams, Supertech dual valve springs, 5 angle valve job, stock ports. Comes with factory intake manifold with a welded EGR, stock ports on intake and stock (62mm i think) TB. Factory oil pan, all new gaskets, ACL tri metal bearings, Valve cover tapped for catch can 2x -10an fittings if no one buys it with catch can. Probably forgetting some stuff. Bill was 3500-3700 for motor minus the supertechs which were 350 from kaizen. 2500.00 Will not pay to ship. Will meet a few hours away if you will supply gas money. I just cant afford to take a 200-300 dollar hit on shipping or gas and have you end up backing out if u decide to meet.
Precision 62mm T4 .68 SOLD
Lovefab SST T4 or T3 manifold, 3" v-band downpipe, 44mm flange/dump tube. SOLD
Tial 44mm, Blue SOLD
Custom Catch Can, powdercoated wrinkle black, K and N filter. -10an lines and fitting, has a baffle. Goes where battery sits on EG. SOLD
Omni 4 bar SOLD
ETS Intercooler 25x11x2.5 2.5" outlet, aluminum piping with tial bov flange, all couplers and clamps. Comes with a Frozen Boost 50mm (same as a tial) 450.00 shipped
NGK AFX Wb with upgraded NTK sensor so you can run leaded fuel without it burning it up (sensor alone is 150.00) SOLD
Autometer water temp gauge, black with white face, shift glow external sending unit that is run in the upper rad hose. All electrical. 70.00 shipped
Autometer C2 -30-0-45psi Boost gauge. Lines, fittings, etc. SOLD
FIC 1050cc injectors. Perfect for an e85 car or a race gas car. SOLD
Ill list more if i remember something that i forgot. I will work with pricing and trying to get the bigger stuff like the motor to you. Check my threads for dyno video and track runs. Track runs were done with the old EGR setup with just a plate, kept blowing it open. Also ran out of gear. Went 98mph breaking up from the EGR in an 8th mile. Log only showed it hitting 13-13.5 psi that day. Made 347whp/306wtq hitting 15.1 on dyno.
I will be glad to make package deals on anything because that will save shipping and get stuff moved. Ill include any lines and fitting that i have for anything so you wont have to buy extra. I know i have a npt fitting and -3an line for turbo along with a dump tube with fitting. Probably 80 bucks in fittings ill send with the turbo.
Sorry for long post. Phone again is 828 850 5974
Omni 4 bar SOLD
Im in North Carolina. As of now everything is sold but the catch can, motor, and the IC itself. Piping and BOV for kit are sold unless guy backs out saturday.
Picture of motor. Looks just like this minus it being a little dirty. This is after i put the motor in when i was installing the turbo kit.
Most of the stuff is sold. I still have the IC with piping and 50mm BOV. Also have an ACT 6 puck sprung clutch. 50 miles on the clutch. Just dyno pulls and about a dozen track passes.
Clutch 340.00 shipped
b16b18
Feb 25, 2011 11:28 AM
mizturyous
Mar 4, 2002 10:32 PM
