Car wont start after I stall out
Old Aug 18, 2011 | 04:07 PM
ant13's Avatar
Default Car wont start after I stall out
I'm still "kinda" new to driving stick so I stall every now and then. Sometimes when I stall out (usually in first gear) my engine will not turn over right away. If I sit there for a minute or two and then try again it might start. Then sometimes it'll start immediately after a stall and then die .
I'm trying to see if any of you guys have had a similar problem and see what the solution for you guys was or if this sounds like a classic example of the starter going out or what not.
Oh and btw my car is a 94lx and I had one of my friends who works on cars change the spark plugs last month when he changed my oil but Im not what kind he used.......Im not sure if this matters or not but Im just putting it out there. All help will be greatly appreciated!
Old Aug 19, 2011 | 01:49 AM
S_F's Avatar
S_F
Default Re: Car wont start after I stall out
I have this same problem. Since I got my Accord I have staled out about 4 times and each time it wouldn't restart for a little while. Any input would be much appreciated!
Old Aug 19, 2011 | 07:25 AM
Lil Tones's Avatar
I'm pretty sure its the main relay.
Old Aug 19, 2011 | 10:01 AM
S_F's Avatar
S_F
But it only happens after stalling. How is that explained by the main relay?
Old Aug 19, 2011 | 10:11 AM
jimmy23lou's Avatar
check your relays has happened to me before
Old Aug 20, 2011 | 06:51 AM
poorman212's Avatar
Are you saying the starter is not turning over the engine? Or is the engine turning over just will not run?
Same question? Why is the car stalling, is yours also because of human error?
Does not sound like the relay is the issue but need more information.
Old Aug 20, 2011 | 09:44 AM
S_F's Avatar
S_F
In my case all 4 times have been because I stalled out starting from a stop, like a noob. Then the engine will turn over but won't fire up. It only lasts about 1 minute or so. Some times more, some times less. Never much more though. Also the car has never failed to start otherwise so I'm assuming it can't be the main relay.
nmaese01
Honda Civic (2001 - 2005)
Mar 14, 2014 11:17 PM
EfBooth
Oct 18, 2011 10:47 AM
mister.wong
Sep 13, 2008 04:45 PM
1baddturbosi
Jul 24, 2007 06:52 PM
winnerpl
Aug 12, 2006 09:27 PM
