FS: 10sec turbo B-series setup part out
first and formost if your lookin to buy parts at crack head prices click the back button now! all my parts are in 100% working cond. without any issues. for the ppl that are willing to spend the money to have good quality parts this is for you! many ppl can vouch for me and my parts.
b18c1 head from a legit Hmotoronline.com(is stamped) gsr. Has supertech springs,retainers,valves, manley keepers, 3angle valve job. all work done by Dave at head games (less than 2k miles on everything) head comes complete besides dizzy, cams, valve cover. $700
GSR hydro tranny w/ quaife lsd, brand new OEM syncros 1-5th CLM cunha installed (only 4 passes on them) tranny is in great shape with NO problems. $1500
Z10 oil catch can $60
JDM b18c1 type R cams - soldddddddd
OEM gsr axles both sides $100
OEM gsr shift linkage $100
OEM gsr engine wire harness (not hacked up) $100
OEM gsr half shaft $80
Hasport b-series mounts for eg (pretty much brand new) - solddddddddddd
Hondata s300 P28 ecu w/ boost by gear option installed - solddddddddd
hondata boost solenoid $80
hondata 4 bar map sensor $80
96-00 EK doors cut for the track saves about 50lbs per door $80 for both
GSR starter - solddddddd
GSR altenator - $60
ATI race crank pulley dampener (best thing i bought for my motor) b-series - soldddddd
Turbo setup - SOLDDDD
built block - SOLDDDD
609-933-0536
GSR altenator - $60
609-933-0536
JDean6pac
Sep 1, 2011 11:16 AM
