What parts other, than the engine, should I be taking? (for a b18b)
Old Oct 3, 2002 | 12:25 PM
s0liDyNe's Avatar
Default What parts, other than the engine, should I be taking? (for a b18b)
alright, I'm going to be salvaging a b18b from an integra, what other parts should I be taking from it? I'm going to be puttin it in a 91 civic si. Can anyone help me out with what I'm going to need. Heh the only things that come to my mind are ecu, and maybe the tranny?
There's a wealth of good condition teg's that I can be salvaging parts from, I just dont know what I need.
[Modified by S7pWn4g3, 9:25 PM 10/3/2002]
Old Oct 3, 2002 | 12:29 PM
RenoRacing's Avatar
Default Re: What parts, other than the engine, should I be taking? (S7pWn4g3)
axles and rear mount and maybe shift linkage
Old Oct 3, 2002 | 12:32 PM
HF2ZC's Avatar
Definitely get the transaxle, ECU, and shift linkage in addition to the engine.
Old Oct 3, 2002 | 01:16 PM
s0liDyNe's Avatar
Default Re: What parts, other than the engine, should I be taking? (HavokRacing)
which is the rear mount?
[Modified by S7pWn4g3, 10:21 PM 10/3/2002]
Old Oct 3, 2002 | 01:21 PM
spettinger's Avatar
there will be a black bracket attached to the transmission that bolts to the rear subframe mount. get it. also take the master cylinder, rear disc brakes, e brake cables, front knuckles, you name it. big brakes.
Old Oct 3, 2002 | 04:05 PM
andrew dc's Avatar
Default Re: What parts, other than the engine, should I be taking? (wreckedhatch)
take the prop valve/ booster/ mc/ disc brakes
Russ Carr
Honda CR-V & Element
Sep 5, 2018 11:58 AM
ezark
Sep 24, 2008 02:36 PM
dx_blk_hatch
Mar 16, 2007 07:06 AM
sleepyhamsterlx
Nov 3, 2003 02:46 PM
