another won't start
well i just rebuilt the engine (D15B7) in my 92 dx. she'll crank and crank but won't fire over. everything is plugged back in and all lines hooked up properly. i've searched but can't find anything, if anyone has any ideas let me know.
timing is good, we've retimed it 3 times today, i also know i'm getting fuel and spark.... don't know if this is an issue, but while cranking it is now throwing a code which i'm heading out to go check now
--Brett
--Brett
haven't gotten the code yet. still searching for the connector. this might take a while since someone has tried to 'mod' this car in the past. i'm still replacing stuff they've removed trying to fix her.
but the code only shows up after i've been cranking for about 8-15 seconds
--Brett
--Brett
well fixed the CEL issue. all it turned out to be is the wrong fuse in for the ECU..... had a 20 amp, now has a 7.5.
but i'm still having a no start issue. i'm running out of ideas. gonna go clean my IACV and FITV and do some thinking...
--Brett
--Brett
luckystryx
Aug 29, 2018 06:15 PM
$ISELLTOU4LESS$
Mar 26, 2006 06:36 AM
