Suspension & Brakes Theory, alignment, spring rates....
Ground control adapters for koni?
Old Aug 17, 2011 | 03:03 AM
mish__'s Avatar
Default Ground control adapters for koni?
So, i have koni yellows and i just got some used ground controls from this guy who used it on his del sol as well, but paired with his stock shocks.
The ground control sleeves don't sit flush to my konis, so it's basically made for stocks, etc... but, not koni specified
are there any ground control adapters i could use to put them on my konis? i'm low on cash, so purchasing a new set of ground controls specified for konis is out of the question will the skunk2 adapters work since the regular ground control sleeves are the same diameter as the skunk2 sleeves? i am open to buying ground control sleeves specified for konis, but can't find any. i might go with the skunk2 metal adapters. has anyone tried it?
thanks.
Old Aug 17, 2011 | 04:24 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Ground control adapters for koni?
Last we heard from eibach they don't exist and if they did would be dangerous.
You need koni specific ground control coilovers. Phone up Eibach.
Old Aug 25, 2011 | 10:45 AM
STOCK_SOHC_DX's Avatar
Back in the day GC made those adapters, I'm not sure if the still do or not. You might want to try contact them.
Old Aug 25, 2011 | 10:47 AM
kaiba's Avatar
http://www.ground-control-store.com/products/index.php
Contact Info
Phone: 530-677-8600 9-5 PST
Info: mark@ground-control.com
Support: mark@ground-control.com
Mailing Address
Ground Control Suspension Systems
3885 Dividend Dr
Shingle Springs, California 95682
Old Aug 26, 2011 | 08:00 PM
micah_m's Avatar
^ Just give them a call and they'll know what you need, they're really helpful.
I had the same problem as you, called them up and they sent me new Koni specific sleeves and perches, for just over $100 shipped. Only thing that sucks is that now I'm stuck with a set of perfect sleeves and perches for any other strut, because Koni just HAD to be difficult and make their's different haha.
Here's a thread from when I was having this problem, JrEk9's pictures are super helpful.
https://honda-tech.com/forums/suspension-brakes-54/how-do-you-tell-what-shocks-will-fit-used-gcs-2730083/
Old Aug 27, 2011 | 03:41 AM
mish__'s Avatar
okay. i got the adapters. you guys know what size the rubber o rings are? i need to pick some up from the hardware store.
unc25
Suspension & Brakes
May 19, 2012 12:15 PM
07rebel
Honda Civic (2001 - 2005)
May 2, 2008 01:43 PM
Daniel_san
Aug 17, 2004 12:26 PM
racekar
Jun 1, 2004 02:11 PM
