Need help from a EF genius please!!
Old Aug 16, 2011 | 10:26 PM
4d_ef_bucket's Avatar
Default Need help from a EF genius please!!
Alright so i did dpfi to mpfi to obd1 and now i have a solid check engine light and cant get it to start, and one time when i tried to start it the engine made a boom sound like there was a small explosion inside the engine how do i fix this??
Old Aug 16, 2011 | 10:32 PM
KINGVEM^^ED6's Avatar
Default Re: Need help from a EF genius please!!
Isn't a solid light a bad ecu
And if ur **** went boom that's not a good thing
Old Aug 16, 2011 | 10:40 PM
no definately not good... but the ecu is fine i got it from a shop that tested it for me
Old Aug 16, 2011 | 10:57 PM
subgeniusdude's Avatar
TDC and CYL wires reversed at distributor? Should be the white and white/blue wires provided you used the TD02U D16A6 Si distributor.
Old Aug 16, 2011 | 11:17 PM
crx_si-r's Avatar
its always bad when people try to jump to the end, especially when they dont know what they are doing. if your not very good with wiring, you should have done a DPFI to MPFI conversion first. and then to obd1. but like its already been stated, check the distributor wiring. also make sure you use a jumper at the 2 prong plug. if you get a CEL the light will stay solid until you ground the SCS (2 prong jumper).
Old Aug 16, 2011 | 11:18 PM
DCRB's Avatar
he can't use the td02u dizzy on an obd1 car. o/p if you are you need to get an obd1 dizzy. what do you mean soild cel? like when you jump the jumper wires does it just stay solid? or is it just on?
Old Aug 16, 2011 | 11:32 PM
The light just stays on when I turn the key to the on position
Old Aug 16, 2011 | 11:36 PM
crx_si-r's Avatar
ok, so then you need to jump the small 2 prong plug located on the lower section of your glove box/passenger kick panel. you can use a paper clip, once you do this your check engine light symbol on the gauge cluster to flash. once it flashes count the number of flashes and that is your CEL.
Old Aug 16, 2011 | 11:44 PM
Alright ill do that tomorrow and see what happens
Old Aug 17, 2011 | 06:06 PM
Alright so I'm going into more detail. I'm using a d16a6 block with a z6 head and intake with a y8 dizzy converted to obd1. At one point I only had codes 7 and 21. I haven't hooked up vtec yet just because this swap has been giving me to much headaches.. when I try to crank it for a couple seconds it sounds like its not getting spark but I checked and it is and when I stop cranking it make a boom noise. My compression is 225 210 215 215 I've checked all grounds and they are good I have gotten rid of the solid CEL and now its back on... I can hear my fuel pump prime.. any chances of it being just a bad injector??
Old Aug 17, 2011 | 06:26 PM
demonicivis1320's Avatar
Seriously dude a y8 distributer is obd2 buddy there's ur problem
Old Aug 17, 2011 | 06:40 PM
Awndre671's Avatar
Icon3 Re: Need help from a EF genius please!!
X2!!! Theres your answer buddy! get a z6 dizzy
Old Aug 17, 2011 | 06:53 PM
turbohatchBnuts's Avatar
what kinda of jumper harness are you using? some jumper harnesses come with a scs wire you can jump. once you jump it you check engine light should flash and then you can pulll the code. do you have the spark plug wires in the right order.
1-3-4-2
| 3
|1 4 dizzy
| 2
engine
4-3-2-1
Old Aug 17, 2011 | 06:55 PM
also you need a Td-42u Distributor off a d16z6
Old Aug 17, 2011 | 07:01 PM
Alright will get a z6 dizzy and my sparkplug wires are right.... is that wats causing that boom noise?
Old Aug 17, 2011 | 07:19 PM
Awndre671's Avatar
That could probably be the reason and yes make sure get the correct dizzy,spark plug and wires
Old Aug 17, 2011 | 07:49 PM
crx_si-r's Avatar
freaking idiots. no you do not need an obd1 specific distributor. your Y8 distributor is fine. an obd2a distributor (96-98) will work fine, its essentially the same as an obd1 but with a single connector instead of 2.
a TD80 will acutally work better for this set up than a TD42 because the bolt locations will match up. if you go with a TD42 you will need to do some mods to the mounting tabs.
Old Aug 17, 2011 | 08:25 PM
Canadian_EF's Avatar
100000% it's your wiring.
verify your distributor wiring... get a test lead to go from the dizzy plug, to the ecu. make sure every wire is the proper one. i had to do it, find the pinout for your distributor and for either obd0 or obd1 ecu (depending on if you decide to verify with or without the jumper harness)
what injectors are you running? d16z6 are obd1, so you don't need an injector resistor box.
Old Aug 17, 2011 | 09:46 PM
But forsure I can't run a y8 distributor?
Old Aug 17, 2011 | 09:51 PM
crx_si-r's Avatar
you can run a y8 distributor. as long as you run an obd1 ecu. you just cannot run an obd1 and obd2 distributor with an obd0 ecu.
your distributor is fine as long as its in good working condition.
Old Aug 17, 2011 | 09:54 PM
alright thanks im running a p28 so you just stopped me from spending money on another one
Old Aug 17, 2011 | 09:56 PM
could the noise be from bad gas my car has been sitting for like 3 weeks
Old Aug 17, 2011 | 10:10 PM
crx_si-r's Avatar
pull your plugs and check them according to the pic i attached and you can see if you have a fuel problem.
Old Aug 17, 2011 | 10:17 PM
alright thank you
Old Aug 18, 2011 | 03:09 AM
A td-42u is for a d16z6 . He has y8 dizzy which doesn't fit the bolt pattern of a z6 head. Does your y8 dizzy fit all 3 bolt holes?
