NC 95 accord ex 4 dr 5 sp- 50k miles
Means of Contact (PM? Email? Phone?): 910 431 2418
Year - Make - Model - Trim Level (E.G. 1997 Honda Civic EX): 1995 honda accord EX
Miles: 500xx
Price: 4259
Title Type: Clear
Activities: McDonalds drive thru
Smoked In?: No
Picture Included In Message: Box? (MUST have one picture minimum or thread will be deleted): Yes
The Bad: mark on front bumper,Heat control **** is broken, use fan switch **** to turn temp hot or cold. Last winter the water control valve was getting stuck every now and then, would assume needs replacing before winter. Front tires hit fender well liner(not the acctual fender) on big bumps
The Good: mint, 24-26 mpg even lil better on highway, everything power, all works fine as it should. tires are 80%. new brakes all around, s2 shocks and springs with 4k on them, oil changes ever 4-5k. has a rockford 12"(p2) sub and 300w amp, sounds pretty good. Radio has usb and aux inputs on face. Recently Alligined(front has spc camber kit) I wouldn't hesitate to take this puppy to California and back! I have been saving up for a new car and I can finally afford, so good bye to my beloved accord.
Located in 28411 wilmington nc
Contact- 910-431-2418
VIRGIN
ALL STOCK(except wheels, suspension, and radio)
sounds great, no ticks, knocks or anything. Maintenance top notch. Previous owner noted mpg for every tank/fill up.
exterior lights, trim etc look brand new, no fading of any sort. (minus scratch on bumper)
garage kept(since ive owned it, stored outside under car shed before my ownership.)
heres all that i have in the glove box, all service papers from Hersons Honda
3/21/96(2,380 miles)
3,750 mile service(oil)
3/28/96(2,440 miles)
7500 mile srvice
8/12/97(7,056 miles)
quick service oil change
8/19/97
ac drain clogged, repaired and cleaned carpets.
12/16/98(11,610 miles)
4 wheel align
head light bulb
ac harness wiring(warranty,recall)
coolant change
24 month service
10/19/00(16,172 miles)
oil change
2/16/01(17,092 miles)
balance shaft seal(under warranty
3/11/02-(19,561 miles)
windshield wiper inserts
82.5k/66 month service
re sealed outer boot
3/3/03-(no mileage entered)
new front sway bar bushings
replaced converter heat shields
battery
90k, 72 month service:belts, plugs,oil change, air filter, oil seal, vc gaskets, trans fluid
new muffler with chrome optional tips..
who keeps up with their car that well? 90k service at prolly 23k???:wtf:
virtually only oil changes and regular maintenance since, I've done oil changes, air filter, spark plugs, transmission fluid within the past 6 months.
TRADES CONSIDERED
Miles: 500xx
Price: 4259
Title Type: Clear
Smoked In?: No
VIRGIN
7500 mile srvice
8/19/97
4 wheel align
head light bulb
coolant change
24 month service
oil change
battery
TRADES CONSIDERED
Matewos
May 10, 2015 11:30 PM
