97 v-tech
Old Aug 16, 2011 | 06:54 PM
gmullin's Avatar
Default 97 v-tech
running on cylinders 3 and 4, all cylinders have 150ish psi on a compression test spark is strong and blue, but cylinders 1 and 2 keep fouling plugs, ive taken bolth plugs out and turned the motor over via the starter to see if any thing came out and nothing? what next
Old Aug 17, 2011 | 07:04 AM
gmullin's Avatar
Default Re: 97 v-tech
any ideas?
Old Aug 17, 2011 | 08:04 AM
GhostAccord's Avatar
If your plugs are being fouled by oil you are probably in need of some new valve seals. Or maybe your PCV system is pulling oil up from the valve cover into your intake manifold. When was the last time you replaced your PCV valve and hose?
Fouled by Coolant/oil you are in need of a new head gasket.
Fouled with gas, check the operation of your injectors, each one should be ticking while running. If you have a heard time hearing each one. If you have a stethoscope use that. Or you can use a long screw driver or a stick. Place one end on the injector body and place your ear to the other. This acts as a stethoscope.
CRXREFIC
Dec 17, 2010 01:45 AM
tomster
Aug 30, 2006 03:17 PM
93FastLs
12
Oct 10, 2004 08:44 PM
johnnycat022
Sep 27, 2004 04:53 PM
respectblades
Apr 2, 2003 06:26 PM
