Kings Performance Honda S2000 800+whp Street S2King - PARTING OUT SALE!!!
Old Aug 16, 2011 | 06:34 PM
Kings Performance's Avatar
Default Kings Performance Honda S2000 800+whp Street S2King - PARTING OUT SALE!!!
We have decided to move on to the next project, so we are parting out the entire set up. Now is the time for you to take adventage of the perfect set up. Amazing spool up, powerband & wheel horsepower.
This is set up has A LOT of R&D and not to mention is the shop and my personal car.
Parting out SALE:
KP Stage 3 Turbo kit: V2 T4 manifold, Stainless Steel 3" Downpipe w/ flex pipe, Stainless Steel Dumptube, PTE 62mm T4 Turbo, PTE 46 wastegate, TurboSmart 50mm BOV, KP 1000hp Intercooler, Real Carbon Fiber wrap Aluminum piping, hose & clamps, 70mm Throttle body, Oil feed & return lines & fittings, Oil filter relocator kit, KP 3" Stainless Steel Full Exhaust $5,500
KP Stage 3 short block: GE Sleeves w/ O-ring, CP Custom pistons w/ upgraded wrist pins, Pauter HP Rods, New ACL bearings, New tensioner, ARP Head studs, New GE head gasket, OEM oil pump, Balance & blue print $4,500 OBO
KP Stage 2 head: SuperTech Dual springs, Ti-retainers, Seals, Bronze guides, Ferrea Comp Valve set, KP Port & Polish, Stock cams, Cam gears $1,600 OBO
KP Dog Box transmission: KP 1st-4th straight cut dog box gear w/ 5th & 6th stock, completly assemble $5,500 + a stock tranny
Innovative Race motor mounts $230 - SOLD!
Competition Clutch Twin disc clutch kit w/ hydraulic bearing set (Just refreshed) $1,000
KP 8.8 rear end kit: Drive Shaft Shop 1,000hp axles, DriveShaft shop Aluminum drive shaft, Ford 8.8 IRS, LSD, NEW 3.90 Ring & pinion, KP Bolt On Sub frame, NEW Fluids $4,500 SOLD!
KP 1000hp Fuel system: KP Surge tank, KP Dual pump bracket, Bosch 044 fuel pump x 2, All black braided lines, All Black AN Fittings, -8 Fuel filter, Aeromotive Fuel pressure regulator, FBM Fuel rail $1,100 OBO
ID2000 Hi-Imp injectors set w/ plug & play clips $650
Koyo Aluminum radiator $150 - SOLD!
SPAL 12" HP Electric fans x 2 $100 - SOLD!
Skunk2 Pro C Full coilover kit $850 - SOLD!
Enkei RPF1 17x8 / 17x9 Flat Black w/ Toyo R888 drag radials $1,000 - SOLD!
Cusco 4 point roll cage - SOLD!
KP Oil & Water tank kit $275
AEM V2 ems w/ 5Bar map sensor $1,100
AEM Boost Solenoid $60
AEM Serial gauge $120
Autometer 45psi boost gauge, Autometer Oil pressure gauge & Autometer Dual gauge pod $100
KP Wire tuck harness & shave engine bay $650
The car was Dyno on a Dyno Jet & the car made :
-550whp @ 15psi on 93 octane gas
-627whp @ 19 psi
-684whp @ 23psi
-813whp @ 32-33psi
Best 1/4 mile pass on Drag Radials : 9.9 @ 142mph
We ran all this passes hitting the rev limiter before the finish line.
http://www.youtube.com/watch?v=JGn-r...el_video_title
Here are some videos of the passes courtesy of GRS-Motorsports:
1st pass: http://www.grs-motorsports.net/video.../22mayo/62.wmv
2nd pass: http://www.grs-motorsports.net/video.../22mayo/92.wmv
3rd pass: http://www.grs-motorsports.net/video.../22mayo/94.wmv
With this set up should see some 9.8-9.7's @ 150mph...
For more info about this car, please email bebo@kingsperformance.com or call (321) 235-2699
WORLDWIDE SHIPPING AVAILABLE!!!
Thanks,
Fernando @ Kings Performance
Kings Performance
Aug 10, 2011 07:11 AM
BmCRace.com
Sep 17, 2005 08:26 AM
BOOSTEDS2K
Jan 25, 2005 12:57 PM
