ENGINE VIBRATION.. Help needed. !!!
hi all,
i have honda accord coupe 2001 v6. i just bought it and has been used over 200000. the issue is that the engine vibrates at idle and at 2k rpm.
i replaced all engine and gear mounts, power plugs,checked coils, cleaned injectors and changed the timing belt but the vibration is still there.
i took it to dealer and after keeping the car for 4 days with them, they were unable to find the problem. they said they are not getting any error code regarding the engine.
if i remove the MAP sensor cable at idle, the engine stops vibrating but check engine sign appears. that what i told to dealer but they said its not MAP sensor issue.
if some had faced such problem and knows what exactly problem is please help me.
IBriaIN
Feb 10, 2011 05:34 AM
