Need Help with H23A bluetop Swap
I have a 2000 Honda Accord Ex. I plan on swapping the engine now that its knocking, for a H23 motor. Im also swapping out the tranny for the H22... But im not here about that.
JDM Vtec/Blue Top - 97-01 Honda accord Wagon
This H23 seems to be really rare. It's hard to finding info about it. or even the swap info. Before I buy anything I would like to know the parts needs.
Its there any change in mounts, wiring, What ECU I should use. is H22 T belt, water pump, seals, tentioners compatible?
I need the full scale, because I want this swap, but If its gonna cost more then what I have estimated already I may bail out.
Please give me your info on the Engine swap parts. Im trying to get this done soon.
Is it possible to pass emissions after the swap?
Bumppppppp 4 some info might find some help here
https://honda-tech.com/forums/honda-prelude-4/jdm-h23a-vtec-blue-top-mystery-motor-true-facts-questions-2341343/
Im not sure what mounts you need, but yes the h22 parts will work. It is an awsome motor and try not to bail if you can afford the swap. Explicitspeedperformance.net has swap part and are a fountian of information. They have this motor in a crx boosted. GL with your swap
