Transmission & Drivetrain Gearboxes, Differentials, Clutches
H22 Turbo transmission
Old Aug 15, 2011 | 03:49 PM
SupraManAG's Avatar
Default H22 Turbo transmission
Feels like I'm hitting a dead end. Options on transmission and no decision.
I'm building my H22 turbo Acura CL. S372 .90a.r, Darton wet sleeves, 9:1 ratio CP pistons fully built head... Power 600-700hp
Now transmission I'm a little lost.
Input please. Considered doing custom gears able to withstand power to wheels.
Was considering H2B conversion but cons have me thinking.
Old Aug 16, 2011 | 08:09 AM
Gearspeed-Performance's Avatar
Default Re: H22 Turbo transmission
I would go H2B since there are a lot more options available for the B-Series transmission. With the B-Series you have a plethora of gearing options and manufactures that make aftermarket gearing.
Old Aug 16, 2011 | 05:05 PM
SupraManAG's Avatar
Issue with that is that B series tranny will require extensive fabricationg including cutting frame and fitting transmission in bay. Apparently accord frame will not support tranny under normal conditions
Old Aug 17, 2011 | 12:09 AM
asianpoet's Avatar
i would use a f22 trans (longer gears for boost) and get the synchros replaced with aftermarket ones..
Old Aug 17, 2011 | 07:42 AM
Oh ok gotcha! We have built several H22 trans that have held up to the power levels but required frequent teardown and inspections to keep it together. Another option is going with an M-Factory Pro Series gearset. Here are the ratios that are currently available:
2.786 1st, 1.900 2nd, 1.430 3rd & 1.100 4th
Do some math and see if that will work with your setup.
Old Aug 29, 2011 | 08:04 PM
extralargenog's Avatar
Pro series won't hold 700. Pm me your number. I've got some info for you. There's a new player coming out on the block for gearsets... but in the heavy Cl.. if it hooks at all... you'll be breaking 2 and 4s anywhere north of 380 tq on varying loads in an oem tranny. They'll last a lil while.. but not long. At 600 making big h tq. Maybe a few hits.. probably not though
Old Aug 30, 2011 | 08:12 PM
andrewkeisler's Avatar
f22!!!
coreyhayman
Nov 6, 2007 02:49 PM
BergRacing21
Jan 12, 2006 03:43 PM
abeaujuin
Aug 24, 2004 06:22 AM
quickLSt
Sep 16, 2002 10:41 AM
