b16 wiring question.
Old Aug 14, 2011 | 11:31 PM
SuperSlowEF8's Avatar
Default b16 wiring question.
so im redoing all the wiring on my crx and doing a wire tuck. it seems that there is a green/red wire and a black wire coming from the main fuse box (shock tower one - c214) both cut, and another wire black/yellow still connected.
Can all 3 wires come out? im cleaning the interior wiring harness and after about 2 hours of looking thru diagrams i believe they are the ELD from the si motor?
please correct me if i am wrong or confirm if i am right!
also there are 2 blue wires in the passenger side harness, i cant see to locate where they are coming from on the inside of the car? (mind u the dash is not out of the car atm so i can only see soo far, but if anybody knows where they go to please tell!)
Old Aug 15, 2011 | 05:59 AM
jlicrx's Avatar
Default Re: b16 wiring question.
Old Aug 15, 2011 | 06:37 AM
accordin 2 me's Avatar
This is why i will never do a damn wire tuck......well that and im lazy as ****
Old Aug 15, 2011 | 12:18 PM
diagrams are fine i have them also, yet b19 is the ecu pin for the ELD on pm6, but b19 on pr3 is knock sensor. which means there is no ELD on b16/pr3 correct? looked thru b16 wiring diagram and havent found ELD mentioned anywhere.
Old Aug 16, 2011 | 06:30 AM
jlicrx's Avatar
that is correct - PR3 ECU does not look for ELD - ELD is only on USDM models - not on Canada models either
EF8DayDreamer
Oct 20, 2012 09:55 AM
IGGY
Oct 10, 2006 09:46 AM
beefjerky
14
Oct 1, 2006 07:09 AM
Civichatch972
Audio / Security / Video
Nov 19, 2003 08:29 AM
