New Info for B-series swaps into '96 - '00 Civics
Old Aug 14, 2011 | 06:26 PM
94EG8's Avatar
Seagull Management
Default New Info for B-series swaps into '96 - '00 Civics
Just got done confirming a few things that I've yet to see any mention on.
  1. '97 - '01 CR-V engine harnesses are a direct fit in '96 - '00 Civics with a B-series swap. Use a '97 - '98 CR-V harness in '96 - '98 Civic, '99 - '01 In '99 - '00 Civics (except HX) Tested, confirmed. If using an automatic harness you'll need to do a little extra wiring, more on this later.
  2. '97 - '01 CR-V driver's side fluid filled rubber mount fits '96 - '00 Civics, I don't know if it's any stronger than the civic unit, but it fits, tested, confirmed
  3. For those doing LS/B20 swaps into '99 - '00 Civics (except HX) '99 - '01 CR-V distributors use the correct small plug eliminating any cutting and splicing. Confirmed.
94EG8
25
Nov 2, 2023 09:06 PM
Mehdi Khelili
Jul 17, 2016 05:26 PM
slammed4dreg
Feb 20, 2014 10:34 PM
