GSR crank balancing/rpm
Im building another all motor b18c at the minute and i have a question for some of the more seasoned builders.
I have always used my ITR or Eagle crank before and now i will be using the GSR crank.
My rev limit is usually at about 9300rpm and my question is will the GSR crank be ok at these revs or should i have it balanced before i put it in??
Every factory crank I've ever had re-balanced came back barely touched. Honda cranks are very well balanced from the factory. You will probably be fine, but it never hurts to have them check it and correct it if needed. Its cheap insurance if you ask me!
