2000 Civic si cluster on my 97 civic hx question
Old Aug 14, 2011 | 11:00 AM
rawrjaay's Avatar
Default 2000 Civic si cluster on my 97 civic hx question
so this guy wants to trade me my cluster in my hx
for his 2000 civic si cluster with 75 dollars on top
but my question is,
since i have a hx, does that mean everything will be the exact same on the si cluster?
even the green dummy arrow light that tells you when to shift?
Old Aug 14, 2011 | 11:06 AM
rawrjaay's Avatar
Default Re: 2000 Civic si cluster on my 97 civic hx question
also, the si cluster has 177xxx miles on it and mine has 130xxx so would it be easy to put the si cluster back to 130xxx miles? to roll it back or whateveR?
Old Aug 14, 2011 | 11:16 AM
ReDHaTcHyGuy's Avatar
the Si cluster doesnt have a dummy light
Old Aug 14, 2011 | 11:26 AM
rawrjaay's Avatar
so that means everything else will work besides the green arrow (dummy light) ?
all the gauges and the rpms, and the fuel tanks, and speedometer should all be accurate just as the stock one in my car?
thanks for the help by the way man, im just trying to learn
Old Aug 14, 2011 | 11:38 AM
Former User's Avatar
Swap the speedometers.
Old Aug 14, 2011 | 11:48 AM
rawrjaay's Avatar
well then wouldnt my speedometer part look different compared to the rest of the cluster?
http://img166.imageshack.us/img166/2...0479ca3ma0.jpg
https://passwordjdm.com/images/Produ...er%20Large.jpg
looking at the pictures side by side you can tell.
or am i wrong?
Old Aug 14, 2011 | 11:50 AM
or am i wrong?
You are right.
Old Aug 14, 2011 | 11:53 AM
rawrjaay's Avatar
You are right.
so is there any way to roll it back or do you think its to hard?
Old Aug 14, 2011 | 11:57 AM
That's not something I've done, so I can't tell you. There may also be legal issues to consider.
Old Aug 14, 2011 | 12:01 PM
rawrjaay's Avatar
well nothing is illegal because im not frauding the miles, im actually setting the miles right back to normal, selling the car with the si cluster that has 177xxx miles on it when my car doesnt have that many miles is illegal (:
but thanks,
ill try to see if anyone else knows how to roll them back
Old Aug 14, 2011 | 12:07 PM
apexi_rsx's Avatar
miles on an old vehicle don't really matter im sure if u try rolling it back u will most likely break it.. after 100k most cars do not loose much in value because it cost more to repair and replace things more frequently. if u want the look of the si cluster which i believe is over rated then swap. if ur fine with the one u have keep it. most si clusters are selling from 150-180. it will all plug and play also 97-01 crv clusters will plug and play in your hx.
Old Aug 14, 2011 | 12:32 PM
rawrjaay's Avatar
if i took the original cluster to show the miles and the si cluster to a dealer, would they roll it back?
Old Aug 14, 2011 | 01:36 PM
HondaPartsHero's Avatar
Technical Hero
I doubt it. Plus no one will tell you on here how to do it because although in your case it may be legal, people can use the same method illegally.
Old Aug 14, 2011 | 01:42 PM
pliskin8's Avatar
no they wont, cause unless i'm mistaken i believe its illegal to roll back miles in any situation, period. They will (i've seen a couple dealers do it, not sure if they all do) sell you the speedometer assembly(NEW) and roll it to the miles you request
spliftacus
Mid-Atlantic (Sales)
Jul 16, 2010 08:35 AM
BolisticSi
Mar 6, 2006 08:31 AM
viktoryv1
Dec 2, 2005 10:18 AM
