URGENT questions for my 99 accord
im having idleing issues after a problem with my egr. i cleaned it but unsure if i got all the crap out of it and im still getting my exaust gas recirculation code when i scan it. now after doing that my idle is staying at 1500 in park and neutral. i broke off i plastic piece thats connected between the air filter and throttle body that hooks up to a cicular small peice north of the EGR unit. not sure what it is but if someone could specify and explain what it does and how it affects my car. its the hose on the top of it and the bottom hose goes into my engine between the 4 fuel injectors. im also getting a few other codes which include catylatic converter emissions and tourqe converter solenoid circut....
can you guys give me a hand because i dont have much expierence with honda accords and have been fixing it myself. thanks to all in advance much appreciated because its KILLING my gas. im getting 10 mpg now from getting around 30 last week
IF whatever you broke opened up the intake system it's going to idle high because you have excessive air going into the engine.
Did you replace the egr gasket and make sure you scraped all of the old gasket before putting it back together and putting a new gasket on ? They sell gasket scrapers at Walmart in the tools section made by Stanley. It's like 5 bucks.
It depends on how bad you disturbed it. If you were able to remove the egr valve and be sure it was not disturbed you could probably get away with not replacing the gasket.
alright i guess i might as well replace it. what about the tourqe converter solenoid? i heard thats a huge problem. what action should i take with that because thats a major concern for me
http://i1192.photobucket.com/albums/...814_144421.jpg
http://i1192.photobucket.com/albums/...814_144439.jpg
you can see where the hose is hanging and also connected to the air duct and the piece on the left that it broke off of.
those pictures are pretty clear. im going to the junk yard tomorrow to see if i can grab the vacuum and some plastic pieces to reseal the vacuum seal. whats the plastic piece called hooked up to the center or fuel injectors 2 and 3? its also connected to the bottom of the vacuum.
Joshua those pictures really aren't clear at all
they are blurry and at all sorts of angles without much aspect to the viewer.
However, that said here is a diagram of what you have broken, I'm still trying to locate the actual part and its name which should help you in its replacement.
http://www.hondaautomotiveparts.com/...8V6%29+%281%29
Also at some point you may just want to consider giving it to a professional to fix......
Here you go
http://www.hondaautomotiveparts.com/...ENSOR+%28V6%29
Part No. Illust. No. Reqd.Qty. Description Color List Price Our Price
36281-P8A-A02 012 001 VALVE COMP,AIR AS 105.33 73.73
they are blurry and at all sorts of angles without much aspect to the viewer.However, that said here is a diagram of what you have broken, I'm still trying to locate the actual part and its name which should help you in its replacement.
Here you go
