LS/VTEC Head Gaskets. B18/B20 same or diff.?
Old Oct 3, 2002 | 09:46 AM
Shft@9GSR's Avatar
Default LS/VTEC Head Gaskets. B18/B20 same or diff.?
Are the B18(non-vtec) and the B20(non-vtec) gaskets the same as far as oil and coolant passages? I know the bores are different sizes.
Question is...If using an LS/VTEC with a B18 bottom end and GSR head, do I have to use a B18 Head gasket? Or can I use the B20?
Since it looks like the cometic gaskets are just B16(vtec) gaskets. (At least the last 3 or 4 that I've gotten pretty much are exact to a b16vtec gasket.)
I need an 85mm and it just seemed more logical to get the B20 gasket and not have to remove as much material as having to on the B18 to acheive the 85mm.
Thanks.
[Modified by Shft@9GSR, 6:46 PM 10/3/2002]
Civic483973
Jul 11, 2010 12:57 PM
adamrich33
Oct 12, 2008 04:54 PM
UnknownDC2
Jul 17, 2008 05:26 PM
blackcrx16
Feb 28, 2008 04:04 PM
Dan-Dillinger
13
Sep 5, 2005 01:39 PM
