rear lower tie bar install
Old Oct 3, 2002 | 09:42 AM
Qwikrex's Avatar
Default rear lower tie bar install
How do I install a rear lower tie bar on my Si? Do I have to jack the car up in order to do this or do I just leave it on the ground?
Old Oct 3, 2002 | 09:57 AM
CheezeFrog's Avatar
Default Re: rear lower tie bar install ([VTEC]TL)
I jacked my car up a few inches to give me room to slide under the car. It also relieves spring pressure so that when you remove the inner LCA bolt, the LCA will stay in place, for the most part. It's pretty easy. 10 minute job at most with air tools. 20 mins if you gotta use hand tools. Don't try to take the nut off that the bolt threads into, because it's welded to the subframe.
BROOD's Avatar
If it requires removal of the lower control arm (lca) bolts...yes you will have to jack it up. For safett use jackstands while you are under there.
[Modified by SLPR, 10:58 AM 10/3/2002]
EvaSivE
Honda Civic (2006 - 2015)
21
Aug 9, 2008 03:11 PM
joethejoeman
Feb 22, 2007 10:00 AM
Calsonic180
Jan 24, 2005 09:48 PM
Blkcoupe
Oct 20, 2002 06:40 AM
au-gsr
Feb 26, 2002 04:42 AM
