is there hi-temp paint for plastic? so i can paint timing belt cover?
Old Aug 13, 2011 | 03:59 AM
crxaddikt's Avatar
Default is there hi-temp paint for plastic? so i can paint timing belt cover?
not long ago i painted my zc valve cover a gunmetal sort of dark gray color with dupicolor hi-temp engine paint, most people i notice seem to leave their timing belt cover off either just cause they like how it looks, or cause they have problems shuting the hood with it on, but i keep my timing belt cover on cause i want to protect the timing belt from stuff getting on it and try to keep it good for as long as i can before having to replace it.
so after painting the valve cover it looked cool instead of the plain old black factory color, but now i notice the timing belt cover is black plastic, which is ok, .......
but i was wondering, is there a way i can paint the black plastic timing belt cover so it matches the same color as the valve cover ???, so it all looks like one single unit, all matching ?,
like is there a high-temp paint that is good for using on plastic parts in the engine bay ???
and if so has anyone used it with good results ???, or is it not worth doing, cause chipping off etc....??
i was wondering not only for the timing belt cover, but if i found a good hi-temp paint good for use on plastics, i could paint some other plastic parts inside the engine bay too ......
Old Aug 13, 2011 | 05:16 AM
TearSDMF89dx's Avatar
Default Re: is there hi-temp paint for plastic? so i can paint timing belt cover?
just use a plastic primer and regular paint the timing cover doesn't get that hot ...hence why its made of plastic....ive done even valve covers in o.e. matching colors without using high temp and they last for years
Old Aug 14, 2011 | 02:58 PM
crxaddikt's Avatar
so since you say the timing belt cover does'nt get that hot, then would i even have to buy a paint thats even labeled as a "hi-temp" type of paint?? or you think regular would do fine? like Duplicolor regular for plastic?
i could try to see if the same hi-temp engine paint i used for the valve cover would work on the timing belt cover, cause then it would be matching all one color,
i read it helps to sometimes mildly rough up plastic with mild sand paper so the surface has something more to grip to,
Old Aug 14, 2011 | 03:31 PM
KINGVEM^^ED6's Avatar
Try krylon fusion its made for plastic or just buy a new timing cover from honda
Old Aug 15, 2011 | 03:45 AM
you wanna rough up anything your gonna paint at least a little bit
Old Aug 16, 2011 | 05:51 AM
1990edsedan's Avatar
and make sure it is oil free before painting - wipe it down with some acetone.
EG-SIXV-TEC
Paint and Body
12
Jun 15, 2013 10:23 AM
The_Honda_Guy
13
Apr 20, 2009 07:58 PM
Stillo
16
Jan 4, 2009 09:06 PM
noble4ws
Nov 11, 2003 05:27 AM
